Home Forums Printing Discussions Mimaki Printers Problems Printing Dark Blues on Mimaki JV3
  • Problems Printing Dark Blues on Mimaki JV3
    Posted by Praveen Jayawardene on 10 July 2011 at 08:37
    Hello Guys,
    Hope all is well.
    Can anyone share their experience with the printing dark blues.
    I’m trying to print a particular blue , its almost like a navy blue .When i print i get this magenta band line come through the blue .Very fine lines of pinkish colour.
    Is it the RIP struggling or the printer struggling to print the right colour?
    Mimaki jv3 130sl
    photo print rip
    Any help would be great.
    Cheers,
    PJ
    Stafford Cox replied 14 years, 5 months ago 4 Members · 5 Replies
  • Russell Huffer
    10 July 2011 at 11:07
    Can not shine any light on your problem but will watch this thread as we had a job to do the other day and this was large blocks of solid blue almost navy and these printed with very strange lines/variations through them.
    I have a Mimaki JV33 using Wasatch RIP so not a million miles from your setup.
    Kind regards
    Russell.
    10 July 2011 at 11:48
    yes has been a slight problem, i found the heat was too high causing the vinyl to become slightly unstable,now down to 35 deg. dark blues are around 250% ink so the vinyl has to be able to take it.
    also double check feed calibration and bi-directional alignment makes such a difference with banding. along with head speed, full scan print should be on as this gives each print pass a equal time between the next, allowing the ink to settle in a more controlled manner.
  • Stafford Cox
    22 July 2011 at 11:37
    I would say from your explanation that it is most likely to be a print head calibration problem. Have you had any work done on your printer lately? As much as i don’t know that particular RIP, I doubt very much it is causing that sort of problem
    Stafford
  • Praveen Jayawardene
    22 July 2011 at 11:42
    Hello ,
    i did have a tech put a new black head in recently. Was a mimaki tech and was suppose to do all the calibrations.
    Do you think this could be related?
  • Stafford Cox
    22 July 2011 at 11:51
    Possibly. Obviously I’m only going by the small information I have been given so far so I don’t want to speak badly of whoever it was. It sounds likely to me that it’s the slant adjust that’s out, that CAN cause similar problems to this, as can some of the other calibrations for that matter. When you say it was a Mimaki tech, do you mean somebody from Hybrid?
