Home › Forums › Printing Discussions › Roland Printers › Problem With Test Print Roland Printers Problem With Test Print Posted by Paul Seamer on 20 October 2008 at 11:32 Hi Guys, I have done a test print and it isn’t firing on all nozzles. What can I do? I have cleaned around the print heads. Please Help David Rogers replied 17 years, 2 months ago 1 Member · 1 Reply 1 Reply David Rogers Member 20 October 2008 at 12:21 One option is a head soak. Switch off MANUALLY drop the capping stations. Push carriage out of way. Clamp off drain pipes. Fill capping stations with cleaning fluid. Push carriage back into position & wind up the capping stations. Leave for a few hours…. UNDO THE CLAMP!!! Run a couple of clean cycles…test again. You can also do a ‘powerful clean’…but you’d better have a LOT of ink ready to waste 😥 Dave Log In to Reply Log in to reply. Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Log In to Reply Start of Discussion 0 of 0 replies June 2018 Now
