Home Forums Sign Making Discussions Traditional Problem with "signwriting" on doors…….
  • Problem with "signwriting" on doors…….
    Posted by Chris.Sullivan on 21 February 2010 at 19:34
    Hi all,
    got a bit of a problem with a job i`m doing.
    Have been asked to do some standard signs on doors in pubs. "gents" " ladies" etc..
    Apart from turning up Thurs as agreed with the "designer" and finding out the doors i was due to paint on hadn`t been repainted. So i rearranged for today and set about my job.
    For this i was using a vinyl mask (stencil) and one-shot paint.
    i know some of you traditional people will frown on this but i was in a rush and not fully competent on using oil and brush freehand yet. (For those that don`t know i`m a chalkboard artist and can use poscas freehand all day long)
    The prob i`m having was on one of the doors as i was removing the application paper some of the stain/varnish came away with it. No probs i thought as i will just touch up afterwards. Unfortunately once i then came to remove the mask it took away even more stain/varnish and with that the enamel i`d just put down!.
    It appears to me this set of doors just hadn`t had enough time to set yet (although felt perfectly dry) as some others i`d done in this pub were no problem and no paint was lifting off.
    any ideas or tips for future ??
    Andy Gorman replied 15 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
    21 February 2010 at 19:55
    i’m not a hand painter but i would give it the same amount of time as when applying vinyl, i always recommend to the customer that we need at least 7 days for the paint to go off and even then, i always point out that if the base coats etc have not been properly done, that there’s a chance the paint will lift off, no liability etc.
    i know the horse has bolted but it’s worth knowing for future use.
    i put stickers on an old walk through Van that was converted to a burger wagon last year, it had been painted with emulsion and a roller! after removing the application tape i had to fold it up rather than screw it into a ball, all the paint had come with it, the decals stuck great, unfortunately the paint they were on didn’t, half the letters etc went back on with superglue! i saw the van in my recovery customers yard some weeks later with the front smashed in, i hope it wasn’t the bonnet decal flying up and blocking his view that caused it!
    Hugh
  • Chris.Sullivan
    21 February 2010 at 20:09
    thanks for that, will bear in mind for future.
  • Neil Davey
    21 February 2010 at 20:33
    Hi Chris, I would say that the problem is the painter hasn’t rubbed down or keyed the paint between coats.
    Not much help now I know but in the future give a price to paint the substrate yourself then at least you’ll know it’s been done correctly.
    (Afterthought) did you use normal vinyl or masking vinyl?
  • Chris.Sullivan
    21 February 2010 at 20:45
    hi, i use exhibition vinyl. As soon as i`ve done outline i then take off straight away.
    used this process a lot of times over last few years and never had a problem like it appeared today.
    the door was painted in like a wood stain varnish which i`ve done this process on before without these problems. The company i`ve done it for really have rushed this refurb and i presumed two days would of been long enough for the door to dry. Lesson learned methinks.
    Please correct me if i`m wrong but even if an experienced oil signwriter had done this job they would still of used masking tape for the top of the letters to ensure a straight line?! Reason i ask is that i then tested a piece of normal masking tape in an area not seen and even that pulled away the varnish layer.
  • Gareth Hankinson
    21 February 2010 at 23:07
    We had a similar problem last year when sign writing a converted coach which had just been resprayed days earlier. The vinyl went on fine but the application tape (medium tack) caused the paint to go a matt shade, i rang the customer to explain we wouldn’t carry on until it had dried out properly but when i returned after dinner it had flattened off and was gloss again…. strange.
  • Neil Davey
    21 February 2010 at 23:40
    quote Chris.Sullivan:
    Would depend on the lettering style but for this type of work more than likely not.
  • Andy Gorman
    22 February 2010 at 00:01
    I don’t think exhibition vinyl is the same as paintmask.
    Proper paintmask is very low tack. Having said that, I have had the same problem with varnish coming off. Poor preparation is usually the reason. (The decorator’s, not yours.)
