Home Forums Vinyl Cutter Discussions Roland Cutters Problem with PNC-1000 in corel x3
  • Problem with PNC-1000 in corel x3
    Posted by dolenc miha on 12 October 2006 at 09:51
    HI!
    I have trouble with fonts(only with text) when I`m start to cut on the cutter display says;
    ERR: WRONG NUMBER OF PARAMETERS;
    and then just cuts a line crossings.
    sorry for bad English!!!
    Best regards from Slovenia, Miha Dolenc
    Ian Stewart-Koster replied 18 years, 10 months ago 4 Members · 10 Replies
  • 10 Replies
  • Lance Sherrard
    12 October 2006 at 23:36
    Sounds like a problem we had.
    Be sure to use serial cable with the PNC1000
  • dolenc miha
    13 October 2006 at 09:24
    thank you
    i will try to chnge the settings!
    best regards Miha
  • dolenc miha
    24 October 2006 at 08:03
    hi
    I tried different setting on the plotter and so now the plotter cuts shapes OK,
    and I still cant cut anything what I wrote (fonts)?
    Is there any other setting in corel X3???
    please help!!!!!
    best regards Miha Dolenc
  • Nick Minall
    24 October 2006 at 08:22
    Try converting the text to curves first.
  • dolenc miha
    24 October 2006 at 09:36
    Thank you i will try.
    best regards Miha
  • dolenc miha
    6 November 2006 at 06:36
    I still have problel I cant find tool to convert text to curves!
    thank you!
    Best regards Miha
  • Nick Minall
    6 November 2006 at 08:52
    Make some text then go back to the picker tool > right click the text and convert to curves
  • Lance Sherrard
    7 November 2006 at 11:26
    Be sure to use ‘hairline outline’ with ‘no fill’
  • dolenc miha
    8 November 2006 at 08:37
    its getting better
    thank you for your help
    Best regards Miha Dolenc 😀
  • Ian Stewart-Koster
    19 February 2007 at 03:42
    here is the pinout diagram for the serial cable for the Roland camm-1s eg pnc1000 etc. It is NOT a normal straight through serial cable, which is why it is easier to use the standard printer/parallel cable, or buy a serial one from roland specially made…or make it yourself:
    Best wishes!
    P.S. if cutting from winXP, be sure the <size> on the console is set to freey>y, NOT expand X, if you are using Corel.
