Home Forums Printing Discussions Roland Printers Problem with opening versaworks
  • Problem with opening versaworks
    Posted by Martin Armitage on 29 September 2009 at 11:47
    Hi I have a problem with versaworks, it is opening extremely slowly. I do have a hell of alot of files still in versaworks but this is a new problem, cpu usage is showing between 90 and 100%, each file is taking a couple of seconds to open. It looks at the moment it is going to take a couple of hours to open – if it does.
    Any ideas would be most welcome
    Mart
    Jason Xuereb replied 16 years, 3 months ago 2 Members · 5 Replies
  • Jason Xuereb
    29 September 2009 at 11:51
    intialise the application to clear out the job queue and reset versawors from the start menu.
  • Martin Armitage
    29 September 2009 at 17:41
    Thanks Jason,
    I did that, then I needed to verify the printer, so had to find the IP address, it has cleared out the job log but is still slow in loading files, I was also kicked off the network so had to sort that out as well. So fun afternoon was had
    Mart
  • Jason Xuereb
    30 September 2009 at 00:03
    Are you loading jobs off the network or are you saying once they are loaded into versaworks loading versaworks is slow?
    What version of versaworks are you running?
  • Martin Armitage
    30 September 2009 at 10:13
    Hi Jason, version 3.0.2, it is taking a long time to open versaworks with jobs loaded – I have also lost images on the job list section on the right hand side
    Mart
  • Jason Xuereb
    30 September 2009 at 10:16
    You tried updating to 3.2.2?
