Home Forums Vinyl Cutter Discussions Summa Cutters Problem with Cutting on Summa D120r
  • Problem with Cutting on Summa D120r
    Posted by Albion on 9 December 2013 at 14:30
    Hello everybody,
    I have a Summa Cutter D120r and I problems cutting with it!!
    My problem is that when I want to cut something it cuts everything like half of it
    and than returns again and cut the other half…I dont know if you understand me well! An example if I give to the cutter the comand to cut a circle it goes like cut the half of the circle than the other half and done, before was not this problem before was normal and just gave to cut a circle it cuts it all over without interpreting of cutting the half and then cut the half of it again.
    I have the cutter since 1 year it worked all fine but one day I try to cut something as I said before and it does it nor right!!!
    I didnt change anything on my settings or anything it just happend so its weird !
    If anyone has an idea about this please let me know.
    Best Regards,
    Albion
    Andrew Edwards replied 12 years ago 3 Members · 3 Replies
    10 December 2013 at 10:22
    welcome to the forum,
    Have you changed any settings lately? over cut setting perhaps?
    I usually find that uninstalling and re-installing the software will sort any issues.
    regards,
    Hugh
  • Albion
    14 December 2013 at 14:18
    Hello Hugh,
    I did not change any settings only thing I changed is the usb cable but I dont think than USB-Cable can be a problem!!
    I also tryed uninstalling and installing the program but the still the same problem!
    I dont understand whats the problem!
    Best Regards,
    Albion
  • Andrew Edwards
    20 December 2013 at 17:40
    Hi Albion
    It may be possible that you have "panels" switched on in the cutter.
    This feature is designed to split a cut job up into user-defined sections or panels – all lines within the defined area are cut before it moves on to the next section.
    It’s for when you don’t want the cuttter to make big movements back & forwards on a big job to maintain accuracy.
    Have a look on the cutter to see if Panels are switched on.
    Andrew
