Home Forums Software Discussions Corel Software Problem when opening Corel X3
  • Problem when opening Corel X3
    Posted by Mike Grant on 18 May 2010 at 20:07
    I fired up Corel today and it opened the graphic in wire frame. Now for some reason everytime I open it up it reverts to wire frame as default. I have not changed any settings and cant find where to disable this.
    Can anyone help me please ???? 😕 🙁
    Mike Grant replied 15 years, 7 months ago 3 Members · 5 Replies
  • Neil Speirs
    18 May 2010 at 20:21
    under ‘view’ can you select ‘normal’ to revert it back?
  • Andy Gorman
    18 May 2010 at 20:51
    In X4 it is under: Tools – Options – Document – General
    The setting may have changed itself magically, try setting the default back in there.
  • Mike Grant
    18 May 2010 at 21:51
    quote Neil Speirs:
    Neil, that was what I done, but every time I opened up a file it opened in wireframe. I also checked the setting "use current settings as default" and it still did not work. (?) (?) (?)
  • Mike Grant
    18 May 2010 at 21:52
    Andy, I will try that in the morning.
    Thanks.
  • Mike Grant
    20 May 2010 at 22:01
    I checked those settings and it was set to open as "Normal" so I changed the default to "enhanced view" and it works properly now.
    I still have no idea why it happened while all the settings were all correct and unchanged.???? 🙄 😕
