Home Forums Printing Discussions Roland Printers Problem combining print/cut jobs across the roll in VPM
  • Problem combining print/cut jobs across the roll in VPM
    Posted by Peter Dee on 5 February 2010 at 10:17
    If I send to separate print & cut jobs to VPM whether by auto nest or manual layout, I can not set the jobs side by side across the vinyl roll. If I try to do this I get a message "The content on this section of media can not be processed at the same time. Move jobs highlighted in red to a new section of media."
    Even if I select auto nest, although they line up across the vinyl I get the same message.
    Can someone please point out the obvious as to why I can’t set 2 small test print/cut images across the vinyl roll (with lots of width to spare) or is it only possible for print only jobs to do this?
    Peter Dee replied 15 years, 11 months ago 2 Members · 2 Replies
    5 February 2010 at 13:01
    I dont think you can do it because of the registration marks, which are added during the print and cut preview, rather than in the rip. I normally combine multiple P & C jobs before sending to the vmp.
  • Peter Dee
    5 February 2010 at 13:58
    Thanks Peter. I wasn’t using reg marks in this case as not laminating.
    I figured combining the jobs might be the way to go and you have confirmed it.
