Home Forums Printing Discussions Uniform Printers Printing to Static Cling
  • Printing to Static Cling
    Posted by M Brown on 5 February 2009 at 10:33
    Hi all,
    Does anyone print onto static cling media using activasol inks. I have a job to print lots of window stickers, and instead of printing onto clear then backing up with white. I thought it it would be cheaper and easier to use static cling. I’m having problems though. Does anyone have a good set up of their profiles that gets a good print.
    I’ve lowered and raised heat settings. Changed ink limit in rip, but still not good enough.
    Any help is very much appreciated.
    From Mark
    Jamie Wood replied 16 years, 11 months ago 7 Members · 7 Replies
  • 7 Replies
  • Andrew Blackett
    5 February 2009 at 18:49
    Hi Mark,
    We’ve done a few sets of static cling window stickers on our versacamm, sorry to say but we had nothing but complaints from the 5 clients we supplied to. Ended up having to use ultra removable and backing in white.
    But I just used my usual vinyl profile (we’re ecosol max though) Grafityp S12P or oracal 3164.
    Andy
    5 February 2009 at 21:10
    if your backing with digital white vinyl, then print clear with the white profile. This is in theory taking into account that the clear vinyl doesn’t lens/distort colour.
    Only heats and feed rates could be different but dont worry too much
    We tried static cling but its not right.
  • Jason Davies
    5 February 2009 at 21:37
    Mark you need to find someone with an Edge.
    Jason
    5 February 2009 at 23:02
    unfortunately jason is right.
    i printed some lovely small stuff and stuck them around the unit, a few days later removed one and the ink had stuck to the window 🙁
    tried to do some large stuff and was rubbish when i had a moan at the suppliers they said the spec sheet says don’t print on the window side.
    realizing there mistake credited the roll.
  • John Cooper
    6 February 2009 at 07:24
    quote Jason Davies:
    Jason
    😀 😀 😀 😀 You’re too cool Jason
  • Russell Huffer
    6 February 2009 at 07:31
    Been through this one i even got a profile from B&P who supplied the cling and this did not print that good, bit of heat and ;imiting the total ink gave washed out colours but better than ink running.
    Not a good product and oone i try to avoid using.
    Russell.
  • Jamie Wood
    6 February 2009 at 07:43
    We’ve done a lot of this onto white self cling. It works best if the design doesn’t
    have a full bleed, as you need a bit of unprinted vinyl to stick to the window.
    If the design does bleed off, I would recommend reverse printing it onto clear,
    and then backing with either a screen white, or flooding with white vinyl
    through a laminator, although depending on the size, the last option may make
    the label too heavy to stick.
    We use a profile specifically for white self cling from Allprint Supplies. Most
    profiles for white vinyl work OK too. Keep your heat to 35 pre / 35 print.
    Forgot to add that we let it gas out for a minimum of 48 hours to avoid the
    ink sticking to the window issue.
