Home › Forums › Printing Discussions › General Printing Topics › Printing reds – not vibrant/browny
Posted by Martyn on 26 March 2021 at 07:44Hi all, im having troubles to get a vibrant redy red. My reds seem to have a brown tinge and print darker as it appears on the artwork. Is this a common issue as with greys looking green?
Yes im working in cmyk.
Martyn replied 4 years, 9 months ago 4 Members · 6 Replies -
Certain reds can be problematic.
What printer & rip are you using – In versaworks there’s an option to preserve primary colours. It’s been a while since I’ve used VW, but it’s in there somewhere.
The best way to do this is to change a setting in the profile you are using. Click on Configure Profile in Onyx. Then select which profile you are using, and make a duplicate. Select the duplicate, and click Edit. In the Colour Management section, click the dropdown menu, and select All ICC Profiles Off, then click OK. This will force the colours to print using the CMYK values set in the artwork. Use this profile when you’re struggling to get a decent result. For a good red, you could try 100% M & 100% Y. If this puts down too much ink, you could drop the magenta to 95%, which should give close to PMS 485C.
Using this method, I’ve found that the Pantone ColorBridge + swatch book is most accurate in Illustrator, as it uses CMYK values to try and achieve the required colour. Not all of them are accurate, so you’ll need to check against a Pantone book. Most colours look cleaner when using this method, ie if you set a colour to be 100% yellow for instance, it will only use the yellow ink, and not add any of the other 3 inks.
We used this method for years on our Mimaki printers, and it worked well for us. We now have Epsons, and the colours are spot on without having to do any faffing.
That is fantastic jamie! sounds like it will sort out the issue. Thanks very much
I have these files printed and mounted on 5mm pvc. I use them to match to a certain colour.
