Home Forums Sign Making Discussions Vinyl printing problems with Roland sp 540v help please
  • printing problems with Roland sp 540v help please
    Posted by Kev Cringle on 11 August 2011 at 12:33
    Hi all I’m hoping someone may be able to help Ive just replace a head in my sp 540 the reason being is it was leaving spatter when printing black ink , so Ive replaced the head and now it prints great apart from when i have now come to print black text onto a background colour either red or yellow i.e. when it is printing from both print heads, its leaving about a half a mm of white which makes it look like a drop shadow on, effectively looks like the print heads are out of sink, i done what i can as far as bi directional print setup but I’m lost now and to make maters worse i live on the isle of man and there is no engineers that are on island any help would be fantastic ,
    Stephen Morriss replied 14 years, 2 months ago 4 Members · 11 Replies
  • 11 Replies
    11 August 2011 at 13:05
    you have missed out the mechanical alignments but don’t know that machine, when done your bi dir will need setting again
  • Kev Cringle
    11 August 2011 at 13:08
    Here is the image this may make it a bit clearer to what the problem is
  • Kev Cringle
    11 August 2011 at 13:12
    Hi Chris there is a small screw that looks like it would move the location of the print head but i have no idea how to do the mechanical alignment any help would be greatly appreciated
    11 August 2011 at 13:33
    in service mode are 2 set ups for two adjuster screws
    1, to set for skew it prints a test you adjust till correct.
    2 to set the for and aft position prints a test you adjust to suit.
    then the knife has to be set to the new black head position also the knife to reg marks.
    the head mounting screws are delicate and must be treated with care.
    without a manual you will struggle doing these sort of jobs.
  • Kev Cringle
    11 August 2011 at 13:56
    Thanks Chris i unfortunately don’t have a service manual so things are going to be a bit of a struggle by the sounds of it as always its right when you don’t need it to happen ,
  • Derek Heron
    11 August 2011 at 15:12
    hi kev
    give me a call and i can post you my cadet manual first class
    for tomorrow if needed
    derek will need your details again
  • Derek Heron
    11 August 2011 at 15:13
    forgot to mention coming over next friday for manx
  • Kev Cringle
    11 August 2011 at 15:27
    Hi Derek
    Thanks for that much appreciated see u next week for a beer !!!
  • Kev Cringle
    11 August 2011 at 17:13
    Hi Chris thanks for the tips its up and running perfect now a few tweaks of the screws and loads of test prints later and all done, many thanks to those that have helped, this forum is so helpful and of course the people on it,
    Thanks again
    11 August 2011 at 20:51
    pleased all ok
  • Stephen Morriss
    12 August 2011 at 08:51
    Not quite on topic but was it a relatively easy job to do Kevin?
    Reason I’m asking is I may have to do mine soon and was wondering about the alignment.
