Home Forums Printing Discussions General Printing Topics printing pantone colours
  • printing pantone colours
    Posted by Paul Hughes on 22 March 2007 at 19:25
    hi all
    someone please help me out before i jump from some where tall 🙁
    what is the best way to match pantone colours on my cadet?
    I have a cadet with activasol ink and use troop designer 4.0v4
    I do the artwork in coreldraw 12 and import into troop to print, but can i match pantone 138, can I hell as like. I have tried importing as a EPS file and Jpeg. I have played with the rendering intents but no joy, any ideas?, help please
    Paul
    Paul Hughes replied 18 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
    22 March 2007 at 19:34
    Hi Paul – I was about to say I use the Corel pantone colour pallete to assign the correct pantone shade – export as .eps then use the Troop RIP to print. This usually gives excellent results – but I see you are already doing that. 😕 The obvious thing to check is that you are using the right profile for your media, but you’ve probably already done that as well.
    Apart from that – I can’t understand why you are having this problem unless perhaps there is an error in the Corel pallete for that particular shade? Are you having difficulty matching other pantone colours? Can you try assigning the colour from another pallete such as Signlab? Just a thought.
  • Paul Hughes
    22 March 2007 at 19:40
    hi Phill
    don’t normally have a problem but just can not seem to get this job right
    what rendering settings do you use in troop or do you take off the colour correction?
    Paul
    22 March 2007 at 19:44
    I have never adjusted any of the colour correction settings – these are as they were when troop was first installed.
    I’ll try printing a block of this shade tomorrow to see if my Cadet and Troop are matching the colour correctly or not.
  • Paul Hughes
    22 March 2007 at 19:50
    may be that’s the problem Phill I’m trying to be too clever :banghead:
    will see if I can set everything back to default and give it another go
    many thanks
    Paul
  • Graeme Speirs
    22 March 2007 at 20:02
    IHAVE TO say that the corel 12 and 13 colour pantone refernece has been first clsss n any job ive done on my cadet. All im doing is saving file from corel to an EPS and dropping it into troop 5.
    I ran 2 banners for my wife’s work and they are fussy feckers when it comes to colour matching so I was worried and they printed really well.
    Other jobs have also been great. I havent made nay changes from whenI first got the machine.
    Whilst this doenst exactly answer your question maybe it indicates some sort of settings issue?
    CHEERS
    graeme
  • Graeme Speirs
    22 March 2007 at 20:06
    sorry another thought in corel pantone pallette I think there are various options such coated and uncoated? might htis affect the shade?
    right click your object
    properties
    hit advanced tab
    pallettes tab
    then there is a whole host of options there ie: coated, uncoated etc etc might be worth trying small blocks of each
    23 March 2007 at 15:54
    Did you get this sorted Paul. I just tried a test using corel 9 and troop v5 on my cadet using activasol inks – the result was a very close match.
  • Paul Hughes
    23 March 2007 at 17:11
    Hi Phill
    sort of got it sorted, printed out a load of test prints and matched it like that.
    the printed pantone colours seemed to be somewhat darker when held up to the pantone swatch, hard to explain really. I could just be being over critical.
    thanks for the help
    Paul
