Home Forums Printing Discussions Sublimation Printing Printing onto sailcloth question…
  • Printing onto sailcloth question…
    Posted by Cheryl Tissington on 4 September 2006 at 21:17
    Hi there,
    I’m experimenting with printing onto sailcloth with my versacamm.
    Its a thick canvas material with a polyester coating.
    I’ve tried some prints, but the ink just bleeds into the material.
    Having tried all the various profiles that I’ve got, I’m still not getting a good print.
    Q. Am I putting down too much ink ?
    Q. should I lift the head ?
    Any suggestions and profile help appreciated 😕
    Cheers,
    Cheryl 🙂
    Andrew Boyle replied 19 years, 2 months ago 6 Members · 15 Replies
  • 15 Replies
  • Peter Shaw
    6 September 2006 at 12:59
    Sailcloth? You must be nuts !!!
    But if you figure it out let us know.
    Then you can trying Awning Fabric !!!
  • Cheryl Tissington
    6 September 2006 at 13:27
    Thanks for that ! 🙄
    6 September 2006 at 17:55
    there is a SA material they cut numbers out of for sails that would be worth a try i have used a bit of it bit strange at first
  • Peter Munday
    6 September 2006 at 18:16
    Chris I have managed to dye sub that material quite well but unfortunatly it fades in direct sunlight after a while. The only way to print on sailcloth is to screenprint.
  • Rod Young
    6 September 2006 at 18:50
    quote Cheryl Tissington:
    Um, not really a terrible idea. But you need a media profile that is specifically calibrated for that media (i.e., the sail cloth). Unless you have an existing profile for a similar material, then it is really a shot in the dark.
    My first thought is perhaps there is a media profile expert handy (i.e., in your region) that would visit your shop to create the profile. Such a profile would be specific to that type of sail cloth, and that would get your production going.
    You can also look into profiling software to create your own profiles. There should be different software available for you from different manufacturers. If you have access to SignLab 7.1, then I would seriously recommend the Novice Calibration Wizard because it walks you through the entire process of profiling your media.
    Regardless of what software you are using, CADlink is about to post a guidebook with respect to profiling media, and it has much general information that will be of use to you. I’ll post the link when it’s available.
    Cheers,
    Rod at CADlink
  • Peter Shaw
    6 September 2006 at 18:59
    Chris,
    I’ve been asked for the SA material for sails but don’t have a supplier. Can you let m know who supplies it?
  • Cheryl Tissington
    6 September 2006 at 21:57
    So, I’m not "Nuts" then !
    Many thanks for your help Rod. I’d appreciate the link when you have it.
    I’ll just keep playing with the profiles. I’ve got lots of material to work with !
    All the best,
    Cheryl 😀
  • Andrew Boyle
    6 September 2006 at 23:16
    There is a sailcloth you can print on with a generic profile on a solvent printer…it has a special coating will fwd details tomorrow …
    The self adhesive material for sails is Dacron,,,,
  • Cheryl Tissington
    7 September 2006 at 08:25
    Cheers Andrew,
    I’m grateful for all your help.
    Regards,
    Cheryl 🙂
  • Rod Young
    22 September 2006 at 15:36
    Hi Cheryl,
    This is a complete guide for profiling media that discusses issues with regular and speciality media, reviews common printer option terminology and their effect on the job, and provides specific troubleshooting help for a variety of print quality issues.
    Here is the link (registration required):
    http://www.cadlink.com/infoSource/nfo_s … tionHb.php
    Cheers,
    Rod at CADlink
  • Andrew Boyle
    22 September 2006 at 18:43
    Ooops forgot……Cheryl can you pm me monday if still looking 😀
  • Cheryl Tissington
    22 September 2006 at 20:37
    Many thanks for all your help Rod. Much appreciated.
    Andrew, just pm’d you. Hope to hear from you sometime on Monday.
    All the best,
    Cheryl 🙂
  • Andrew Boyle
    26 September 2006 at 18:46
    also this one…explains ripstop and machines
    http://www.3p-inkjettextiles.com/us/produkte/411.pdf
  • Cheryl Tissington
    27 September 2006 at 21:57
    Thanks Andrew,
    I really appreciate your help.
    Cheers,
    Cheryl 🙂
  • Andrew Boyle
    27 September 2006 at 22:03
    Cheryl we did a couple of samples for the sail company….I’ll find out where they get theirs from…it has the coating
