Home Forums Printing Discussions Sublimation Printing printing on to black cotton
  • printing on to black cotton
    Posted by Michael Potter on 27 June 2008 at 09:11
    we have been given an order for several black T shirts and the client wants high quality images applied to the shirts. my problem is I have no idea what materials to try to source to do the job. can anybody give me some options.
    Many thanks mike 😀
    Stephen Morriss replied 17 years, 5 months ago 4 Members · 5 Replies
  • Neil Speirs
    27 June 2008 at 10:35
    It may work out to be to expensive or not worth the hassle for you if the order is only for a few t-shirts.
    Anyway you have the options of producing the transfers by using
    1. laser photocopier (good if you have a suitable photocopier to hand)
    2. sublimation (if you haven’t already got a sublimation set up not then not worth considering for a small order)
    3. large format printer (never used so can’t comment)
    27 June 2008 at 16:11
    if the image is edge to edge A4 / A3, then the laser route onto dark transfer paper will work, essentially you print onto a transfer paper, remove the backing, lay it in position, the use the heat press to fix it. the downside is that anything other than a basic shape which can be trimmed with a ruler or by hand, will take ages or cause probs. the transfer paper is white, and will stay white when pressed.
    hugh
  • graffica
    27 June 2008 at 16:21
    Hi Michael,
    To my knowledge, you can´t use sublimation for dark fabrics.
    Victory Design amongst many others do a very good thermal vinyl for T-Shirts etc. Solid colours only which you cut on plotter.
    For full colour images and photos you´ll need a totally different material.
    I never turn down jobs for small quantities as they invariably lead to more profitable work from the customer or his mates.
    Chris A
  • Neil Speirs
    27 June 2008 at 16:48
    Your right Chris about the sublimation on to dark garments, I was thinking about the xpres A4 ink jet dark paper which we used with an Epson R300 & using genuine Epson inks….nothing to do with sublimation 🙄
    Down side being xpres only supply it in boxes off 100 sheets 🙁
    I’m sure Steve was recommending similar paper from Target & saying how he found it to be less plastic than xpres’s
  • Stephen Morriss
    28 June 2008 at 09:57
    You can get a material simular to the ones talked about here but it’s for solvent inks, then you can print and cut it the same as any other sticker, if you have a solvent print/cut machine.
    Grafityp do one and Xpress do one, not sure who else.
