Home Forums Software Discussions Corel Software Printing object positions and guidelines
  • Printing object positions and guidelines
    Posted by Nic K on 7 May 2010 at 07:45
    Hi all,
    Does anyone know of a quick and easy way to print object positions? It would be handy when fitting cut vinyl graphics to a window if the layout were printed on a page size equal to the window, showing the position (top corner of object) .
    Nic K replied 15 years, 8 months ago 2 Members · 2 Replies
  • Adrian Yeo
    7 May 2010 at 13:08
    Don’t know if its what you mean, but in corel, if you have your format ‘to size’ and build your layout within this format, you can add the actual dimensions using the ‘dimension tool. This is on the same fly-out as the free hand tool.
    Once done you convert the page to curves and reduce to fit on an A4 sheet. Print it out and you have a map of your window etc.
    Just make sure you convert before reducing otherwise it gives you the reduced measurements.
    Might be an easier way, but that’s what I have done in the past.
    Hope that helps
    Adrian 😀
  • Nic K
    7 May 2010 at 14:06
    Thanks Adrian, although not exactly what I meant. I am probably looking for some kind of macro that does it all at the click of a button. Would be great for jobs with multiple objects if the layout positions were automatically printed.
