Home Forums Software Discussions Corel Software Printing jpeg images
  • Printing jpeg images
    Posted by Jason Bagladi on 24 May 2013 at 08:26
    Not too sure if this is the right section to post in.
    I use CorelDraw X4. When I use a combination of vector and jpg files in a design, I export to eps and print via VersaWorks. The jpg part of the design always looks washed out and dull. If I print the jpg direct from VersaWorks, it’s fine.
    Any suggestions on how to resolve this would be appreciated.
    Jason Bagladi replied 12 years, 7 months ago 4 Members · 5 Replies
    24 May 2013 at 09:44
    convert the whole lot to a 300dpi bitmap before sending it to the printer – generally works well.
  • Jason Bagladi
    24 May 2013 at 12:38
    I did try that but I lose my contour cut line.
    24 May 2013 at 13:01
    send the eps as the jpeg is rgb or cmyk normally the vectors look after them selfs
    24 May 2013 at 13:15
    The washed out image is probable rgb, ensure everything is CMYK and if your colour management is set up correctly and you have a half decent monitor what comes of the printer should be sililar to what you see on screen.
    Alan D
  • Jason Bagladi
    24 May 2013 at 18:39
    Thanks all for the quick feed back. I’ll have a play this evening and see what results I get.
