Home Forums Printing Discussions Roland Printers Printing help!!
  • Printing help!!
    Posted by Stephen Ingham on 2 September 2009 at 14:55
    Hi all, can anyone help me please?
    I have created some artwork in coreldraw x3, saved it as a .tiff then opened it in ColourRip 2.2 and where there should be a grey shadow fade effect it just shows a dark solid shadow.
    Then i tried saving it as an .eps and opened it in rip software and when i print it the gradient/ shadow becomes really grainy.
    Please can anyone shed any light on what i might be doing wrong
    Any help or advice is much appreciated
    stephen
    Karl Williams replied 16 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
    2 September 2009 at 15:02
    my preference is to separate the drop shadow and export as a jpg.
  • Stephen Ingham
    3 September 2009 at 07:45
    Hi Chris, sorry if this sounds daft but what do you mean separate the drop shadow?
    stephen
    3 September 2009 at 08:32
    quote :
    sorry thought this was a drop shadow which is a transparent bitmap over vectors and colour rip does struggle with that combination.
  • Stephen Ingham
    3 September 2009 at 13:55
    Am sure i have done this before without a problem, i just can’t figure out what i am doing so wrong….
    stephen
  • Simon.Johnson
    3 September 2009 at 15:16
    Hi Stephen/Chris,
    Please try importing the tiff and the eps file back into x3 to see if the files themselves were corrupted during the save process or if it is the RIP which is failing. If it is the RIP I can give you a download link to test (will deface the prints until licensed) the upgrade version of the software to see if that works correctly.
  • Stephen Ingham
    3 September 2009 at 21:12
    Simon thanks for the reply.
    I have tried importing the .jpeg as you suggested and it looks fine….
    stephen
  • Karl Williams
    3 September 2009 at 21:22
    Watch the sizing when doing a jpeg from Coral mate. For some reason every Jpeg I export Shiraz resizes it sometimes as much as 300mm.
    Try exporting as a PDF and see if that works.
