Home Forums Printing Discussions General Printing Topics Printing from Omega
  • Printing from Omega
    Posted by Neil Thompson on 6 November 2006 at 14:38
    Hey folks
    Need a little help with omega and the gerber edge.
    If I am correct in saying with Gerber omega and the edge, it doesn’t matter if an image is multilayered, omega will flatten it while it prints it. So to avoid any gapping caused by registration, sometimes it helps to set up bleeds or traplines.
    However, I want to add a shadow to a flag, which will probably be black with a 50 Transparency set and superimpose it over the image. Now, how do I stop omega flattening the image before print and thus creating the shadow layer as part of the background, as I want the transparent layer superimposed over the flag?
    Thanks in advance
    Neil
    Neil Thompson replied 19 years, 1 month ago 3 Members · 3 Replies
  • Dave & Rob Lowery
    6 November 2006 at 15:10
    You don’t say if the transparency is an image or a vector file 😕
  • George Zerbino
    6 November 2006 at 21:11
    Neil,
    Set your top shadow (be it a vector or a bitmap, no difference), as an overprint (keyboard shortcut is ctrl + F6) and on top of all other objects.
    If you have the latest 2.51 version, you can check the actual print by previewing the spool file in gspplot, by click on "save to spool file" under the file menu in gspplot, from there choose "include in spool file: print information" and "view spool file", this will then prompt you a location to save the spool file, and automatically will open a new window which allows you to view what the Edge will actually print.
    Hope it’s of help!
    Regards,
    GeoZ
  • Neil Thompson
    7 November 2006 at 11:29
    Thanks Folks
    Great job!
    P.S. Omega is some fun!
