Home Forums Printing Discussions General Printing Topics printing brochures.
  • printing brochures.
    Posted by Adrian Neill on 22 September 2005 at 13:32
    We are in the process of creating our own brochure.
    We have our own Grenadier printer and have considered printing it ourselves?
    Is this a viable option ? or best left to a printer ?
    If this is ok, any recommendations on suitable paper ? and where from ?
    Tim Painter replied 20 years, 2 months ago 4 Members · 4 Replies
    22 September 2005 at 13:53
    well, it might be cost effective for the 2-3 off but not a run of them.
    I suspect the ink will cost
  • RobGF
    22 September 2005 at 17:57
    If you’re not thinking of doing a lot of brochures, one of the options you might consider is finding a printshop with a colour copier. If you can give them a nicely construced PDF file chances are they can be very reasonable in cost. A lot of shops with colour copies have become very serious about copier quality and they test which papers provide better results. Some of these shops are doing some really great quality digital work. Not only will this method be cheaper but chances are it will look lots better too. There is a point where digital no longer is the most cost effective way to go and at that point you might want to talk to a sheet fed litho shop.
    Good luck.
    Rob
  • Terry Gall
    22 September 2005 at 18:16
    If you want a larger run of brochures I would recommend RCS.
    http://www.rcs.plc.uk/start.asp
    They offer good competitive prices and quick turn around.
    Terry
  • Tim Painter
    23 September 2005 at 09:43
    RCS is OK for run of the mill stuff……they achieve there pricing by planning up the jobs and printing yours with others. I have used them for nearly 10 years.
    Most places will take PDF’s these days as stated. Make sure artwork is set up correctly though when creating the PDF. With images at 300dpi and bleeds etc. As Rob stated digital output is ok but you get to a point where litho is more cost affective and truethfully it still is superior to digital.
    What size leaflet / brochure are you thinking of?
    What sort of quantity?
