Home Forums Vinyl Cutter Discussions Roland Cutters Printing a different colour
  • Printing a different colour
    Posted by Phil Green on 15 July 2011 at 19:03
    Hi All,
    Wonderr if anyone has any idea whats happening. I have printed about 48 metres of a logo it all in different pieces to make up lettering. After printing I had a few areas that wasnt right so I went to print a piece to stick in and its completely the wrong colour. I havenet touched anything I have changed 2 cartridges but I would imagine because I have printed such a long length any problems witht the print heads would have come to light. Any one got any ideas its a ROland VP 540
    Phil
    Phil Green replied 14 years, 5 months ago 3 Members · 6 Replies
    15 July 2011 at 19:06
    and your test print is ok?
    printing long lengths on emtpy and then changing the cart will require u to pull the ink thru
  • Phil Green
    15 July 2011 at 19:12
    Hi Dave,
    There are 4 letters and 4 sets of letters approx 1.8 tall all printed and came out all the same colour. But now I go to print its a completely different colour. The first was a silvery blue now these are a purpely colour
    15 July 2011 at 19:21
    I once replaced cartridges in the wrong positions (e.g cyan in the magenta slot, and magenta in the cyan slot) easily done when you’re rushing about 😳
    Thing is you don’t notice there’s a problem until a good while later once the ink has made it’s way through the pipes.
    Could this explain your problem too?
  • Phil Green
    15 July 2011 at 19:28
    Hi Phil, No I checked that its a right pain cause if I cant get it back I am going to have to reprint and laminate it all again
    15 July 2011 at 20:41
    you just said… laminate
    how long did u leave it?
    how warm was your heaters
    maybe ur rolled up ink was still wet and out gassing, the start of the print being the last bit that got laminated was dry
    so was it bad before u laminated it?
  • Phil Green
    16 July 2011 at 09:39
    hi dave yeh completely the wrong colour even before laminating
