Home Forums Printing Discussions General Printing Topics Printer recommendations needed please
  • Printer recommendations needed please
    Posted by Gary Hazard on 19 June 2006 at 14:23
    Hi everyone
    I have just introduced myself in the say hello section and
    could do with some help deciding which way to go when
    starting my new business
    The intro post is here http://www.uksignboards.com/viewtopic.p … 293#157293
    The main problem I have at the mo is the space considerations
    although I had seen pictures of various machines on the web I
    didn’t actually realise how big some of these "beasts" were until
    I visited SIGN UK recently and you see that you not only have the
    front to work from but ya have to get round the back as well to
    change inks and roll etc.
    Consequently I have come the conclusion therefore that in
    the limited environment available that I can only fit in a 30/36"
    machine. Also it would have to be an eco-sol machine as I
    don’t think there would be much room for ventilation.
    My main concern is the possibility that (initially at least) because
    I am starting a new side to my business that the machine may be standing
    "idle" for a few days at a time so what machines are better prepared
    for this ?
    The two machines we are most interested in at the moment are these
    Roland SP-300V
    Rockhopper 38
    Whilst cost for a new machine is not a major issue, if a second user
    one of these models or something similar was available that maybe
    needed converting to eco-sol max inks what would be the possible
    "pitfalls" of buying such a machine ?
    So finally has anyone therefore got any recommendations on a printer or
    printer/plotter to "fit the bill" ?
    Gary
    Shane Drew replied 19 years, 5 months ago 4 Members · 5 Replies
    19 June 2006 at 15:06
    have you considered an edge?
    the problem with eco or solvent printers, they need to be used regularily to keep the heads from blocking. An edge will not have those issues.
  • Gary Hazard
    19 June 2006 at 16:37
    Hi Shane,
    Thought you would be in bed by now (midnight over there ain’t it ?)
    Thanks for the reply but don’t think the edge is wide enough
    also don’t know about running costs perhaps you could enlighten us?
    P.S. Any date yet on when the hand will be fully "functional" 😉
    Gary
    19 June 2006 at 17:00
    quick reply based on above…
    i would recommend the Roland SP-300V.
    either brand new or ex-demo type machine. i personally wouldnt buy a printer from anyone second hand. after sales support etc is a must with thes type of machines.
  • Martin Forsyth
    19 June 2006 at 23:53
    Hi & Welcome
    I would also recommend the SP300 (I have one myself)
    I have limited space, and most of the time, don’t go round the back, but lean over the top to load media 😮
    I have days where I use it for printing, then a few days where I use it as a vinyl cutter only – I have even had it switched off for 4 or 5 days, due to having too much laser work, subli work to do!
    But when I switch it back on it cleans itself, and has been fine – I have had no ‘clogging’ problems at all.
    There are no odours – so ventilation is not an issue at all.
    Thats my 2p worth.
    Good luck with whatever you decide.
    Martin
    20 June 2006 at 01:45
    quote Gary Hazard:
    Hi Shane,
    P.S. Any date yet on when the hand will be fully “functional” 😉
    Gary
    Hi Gary, I only suggest the edge because of its footprint being so small. I don’t have one but plenty here do, they would be better to advise you on operating for and againsts. 😉
    The hand? Physio tells me not to expect too much for at least 4 weeks but will be 8 weeks at least before they will consider stopping physio 🙁
