Home › Forums › Sign Making Discussions › Vinyl › Printed Vinyl on HIPS – help needed removing bubbles please.
Posted by Steve Pearce on 19 August 2014 at 15:09Just picked up a small job of some printed Vinyl applied to A2 sized HIPS sheet (1mm). The printing on the vinyl is fine, but there are more bubbles than an Aero bar after applying to the HIPS.
Tried various methods of application, pre cleaned the sheet before applying, left it 24 hours after removing the protective cover on the sheet (as suggested by the manufacturer), different squeegees, different pressure even used a static reducing spray…all to no avail.If it helps at all, applying unprinted vinyl to the sheet, really straightforward, and no bubbles, as soon as it has been printed, then applied, bubbles form wherever the sheet has been printed..mainly tiny, but various sizes.
can anyone help please?
Steve Pearce replied 11 years, 2 months ago 8 Members · 19 Replies -
there is a clear protective film……have you removed it?
I apply unlaminated prints wet to Hipps
Thanks for your help John. I have removed the protective layer and allowed it to breathe for 24 hours, even tried applying the vinyl to both sides to see if it made any difference….it didn’t.
Tried the wet application also, but found that because of the make up of the HIPS, the wetting solution just pooled.
Should I be using an application tape to apply the vinyl to the HIPS board?
How long are you leaving the PRINTS to dry / out-gas before you are trying to mount them onto the HIPs plastic?
what type of printer are you using?
I use water, iso with a few drops of washing up liquid in it as a application fluid.
I know Rob does not like wet application 🙄 but I can apply pretty much straight off the solvent printers onto Hipps.
Rob, I usually leave them a day before mounting them and we have a Roland SP300i using Eco Sol Max Inks.
John, I have tried all sorts of wet method liquids, but on this HIPS material, it immediately forms into pools (like mercury does) so doesn’t help at all.
Could it be the solvent inks reacting with the HIPS material in some way…there are no bubbles if the vinyl isn’t printed, only when it is?
we’ve done a few of these recently, occasionally wet mostly dry, printed on our roland versacaam with ecosol max inks and laminated – if in a rush we gas out only one hour and apply – no come backs and either way goes down a dream so im thinking its application technique rather than the process – sorry if im wide of the mark just my guess.
FYI we always print to decent media
John 😀
You must be right John, it’s probably my application technique, it’s a mystery though why it only bubbles when its been printed and not when it hasn’t.
FYI we used a metamark MD vinyl, do you have any reccomendations of other vinyls/suppliers that we can use?
If these aren’t laminated then is it possible that once they are printed you are applying a lot less squeegee pressure for fear of scratching them or using a different squeegee? I have no experience personally with printed graphics on hips just cad cut.
Have you tried using 3m primer? It has helped me in the past with difficult plastics.
I would probably try an air release vinyl with laminate, or apply through a laminator.
The problem is probably caused by the ink still gassing out, as Styrene isn’t porous. -
Thanks to every one who commented, some great suggestions for me to try out, hopefully one of them will solve the problem.
The air release products look really good, we have a possible frosted window graphics job in the pipeline and the samples we have tried are easy to apply and look great. -
If the water is pooling then there is not enough soap in the water to make it act as a wetting agent, I’ve done HIPS wet before and had no problems.
Hi Steve, I used a special application fluid (Blue in colour) from Signgeer, other people had recommended it to me as being great. I will try the washing up liquid and water next time…..
what part of the world are you in Steve? if local I would take a look or there might be someone else local to you 😀
Hi John
Ideally, I need to get myself on some sort of training course to at least give me the basics of what I need to complete the simple tasks. Reading through this forum I’ve picked up quite a lot already, but there is nothing better than a hands on tutorial.I could probably teach someone to run a litho press in a couple of days, but it’s the thirty five years of experience that makes a difference when things go wrong, it’s probably the same in your industry.
Some of the sales guys that sell you their materials are a great help and most jobs go really well but every now and then, something like this happens and you are stuck.
quote John Harding:So where are you 😀
He’s in the Wigan area according to the hello thread John :lol1: :lol1:
Martin you little detective you 😀 too far for me now but if im passing
