Home › Forums › Printing Discussions › General Printing Topics › printed fascia sign
printed fascia sign
Posted by Martin Grimmer on 2 June 2006 at 12:23Hi,
Personally I don’t like them but have been asked to do a fascia which needs do be done as a print. Not done a printed one before – is there anything to look out for?
Am a bit worried about the join to be honest, plus fading as south facing. Will get laminated.
Any input appreciated.
Ta.
Martin
Andrew Boyle replied 19 years, 7 months ago 4 Members · 11 Replies -
laminate definately, but avoid yellow if you can, it will be the first colour to fade 🙁 May only be our environment here, but yellow is white in about a year here unlaminated.
George,
havent measured but from memory probably about 15ft wide (think that the 1070 x 170 pixel image supplied will have a bit of a struggle…….)
Shane – ta for that – it is mainly blue so hopefully wont fade so quick.
Martin
Marts i cant see any problem with the join are you mounting it onto foam/dibond first?
George,
yes – will be onto dibond or foam – not sure yet. Guess am over paranoid of the joins not being spot on as will show with the continual print…
will bear your optimism and faith in mind…
thanks
Martin
i usually get both panels on a bench and mount the print as one the cut after then when fitting hope its a nice flat surface
Marts, you cant do a sail track banner? That would fix the join concern.
Martin,
I wouldn’t be worried about the join at all……ignore it….would prefer di-bond [or similar] rather than foam…The new Thomas Cooks, Thorntons etc are all digital onto aluminium and look great.
