Home › Forums › Sign Making Discussions › Vinyl › Printed easy apply vinyl for ease of install for glass
Posted by Chris Windebank on 7 October 2019 at 09:44Morning All, sure I have seen this on here but cannot find it.
Have to supply various window graphics that need applying from the inside and are easy to install by the end user, can anyone recommend such a film?
Chris Windebank replied 6 years, 2 months ago 7 Members · 12 Replies -
Metamark do the metadot which is effectively air release and removable. Hard to cock it up!
there are other brands of course that use the dot adhesive idea.
Cheers Hugh, will blag a sample, also found Easy Dot by Neschen.
We’ve the easy dot from Neshen, great stuff.
If you’re applying on the inside of windows, are they to be read from outside. From memory I think the easydot has a matt finish so it’s not 100% clear.
There are removable clear vinyl’s, we’ve used 3164 clear removable and flooded with white.
temp Iain. If I were installing I would use clear and back with white, this has to be idiot proof ish
quote Robert Lambie:Another alternative is Drytacs Spot-On:
https://www.uksignboards.com/viewtopic.php?t=67936Or their Viziprint range!
Thanks all, getting samples from all companies mentioned
Hi Chris,
Try the Ultraview from papergraphics. Virtually optically clear and a piece of cake to install. Good price too from memory..
