Home Forums Software Discussions Flexi Sign Software Print to file Onyx 10 – help required, please?
  • Print to file Onyx 10 – help required, please?
    Posted by John Dorling on 30 June 2014 at 08:49
    We are using Onyx 10, an HP L26500 and a Summa D160. We use the OPOS barcode system to cut multiple jobs.
    Is there a way to print to file so I can generate a cut path for a job that doesn’t currently have one, without actually having to print it?
    Brian Bollard replied 10 years, 5 months ago 3 Members · 3 Replies
  • David McDonald
    7 May 2015 at 09:10
    Did you ever sort this out?
    Was it possible?
    Macky
  • John Dorling
    7 May 2015 at 09:13
    Not exactly. The only way I could find to do it was to put a cut path on the original artwork and then press print, but cancel it straight away. This generates the cut file but you have to load manually, not from the barcode.
  • Brian Bollard
    25 June 2015 at 06:23
    A bit late sorry but this might help future sufferers.
    Go to Configure printer>Device>Configure Port>Print to file.
    Might be an idea to write down the existing settings for when you change it back.
