Home Forums Sign Making Discussions General Sign Topics print problems on curtain vinly help please!
  • print problems on curtain vinly help please!
    Posted by John Imrie on 24 June 2008 at 10:02
    Morning
    i have printed a company log onto avery signflex and then sprayed with frog juice liquid laminate
    when i fitted the vinyl to the curtain and started removing the application tape the print came with the tape disaster!
    i need to sort this out today does anyone have suggestion/remedy?
    thanks
    john
    John Childs replied 17 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
    24 June 2008 at 10:34
    frog juice and application tape do not go together
  • John Imrie
    24 June 2008 at 10:51
    i suppose we could spray the job once its in place
    are you aware of any other laminate that would work chris?
  • Gavin MacMillan
    24 June 2008 at 12:16
    I was advised that frog juice is not suitable for something like this where it is going to flex all the time. Curtain siders and banners basically.
    G
    24 June 2008 at 13:06
    my only suggestion would be try a bit of wrapping laminate not based on fact though, unlike f04857g frog juice comment.
  • John Imrie
    24 June 2008 at 15:15
    the boys are off to refit i had to use metamark banner vinyl
    it may not be permanent but it will give me some breathing space with the customer and easy to remove!
    the signflex without question is a first class product but it does not hold a
    solvent print and i have never had as much trouble removing vinyl as i had with this stuff 3 men 3 and half hours to remove half a square meter
    i thought of the laminate chris and i will do a test before using on the job
    the metamark held the print and frog juice ok
    but any suggestions of a better process would be much appreciated
  • Kevin Flowers
    24 June 2008 at 15:43
    you could try a liquid laminate, i have used it on banners successfully that are going to be continuously rolled up in between market days
    http://www.clearstarcorp.com/clearshield.asp
  • John Childs
    24 June 2008 at 16:03
    John,
    We printed some Signflex a couple of years ago and, knowing what curtains go through, I wasn’t happy leaving them unprotected. Avery said there is no matching laminate for Signflex, so we did it with the Oracal laminate we had in stock.
    To date they are fine, and I’d happily use it again.
  • John Imrie
    24 June 2008 at 16:14
    John,
    Thats good news chris had suggested this and i had thought of it myself
    just a poiint i was blaming the frog juice for bringing the print of onto app. tape but when i reprinted this morning i dried it of and tried a bit of medium tack tape print came of onto paper
    when i reprinted on metamark banner it was fine even with frog juice
    although i think avery signflex is a great product i would not recommend for printing or it may be my printer jvc33 full solvent
    i am a bit wary of using it in case we have to remove it again is anyone aware of a material that takes a print properly and stays on curtains and can also be removed if there is a problem
  • John Childs
    24 June 2008 at 20:49
    quote John Imrie:
    :no1:
    For curtains there is only Signflex and APA. Neither will come off without a fight.
