Home Forums Vinyl Cutter Discussions Roland Cutters print onto Dacron
  • print onto Dacron
    Posted by Dan Osterbery on 27 October 2009 at 17:50
    Hi guys,
    has anybody ever printed onto dacron? it is basically polyester, so i should be able to do it with a verscamm, but i have printed with about 15 different profiles and they all seem to bleed and i am running out of sample space??
    any suggestions appreciated
    thanks
    Dan
    Dan Osterbery replied 16 years, 2 months ago 2 Members · 2 Replies
    27 October 2009 at 22:35
    dan if the material is bleeding then you can only reduce the total ink load, to a point that it does not bleed. then in may look a bit flat with the colours.
    some of these materials are coated on one side and are reverse wound on the roll.
    to test for this – squeeze the material between finger and thumb and see if one side sticks to you that is the coated side.
  • Dan Osterbery
    28 October 2009 at 08:23
    thanks chris! will try dropping ink load, this is one side adhesive dacron! I’m still trying to find a solution for sail material!!
