Home Forums Printing Discussions Roland Printers Print head prices
  • Print head prices
    Posted by Dan Osterbery on 26 May 2010 at 14:34
    Hi All,
    anyone had print heads replaced on a versacamm before? Roughly how much were you charged? I have been quoted 800 euros each and think that might be a bit steep? I could be wrong? Any experience appreciated!
    Dan
    p.s SP-540 machine
    Jason Xuereb replied 15 years, 7 months ago 7 Members · 11 Replies
  • 11 Replies
  • Soyeb Ravat
    26 May 2010 at 15:30
    pretty sure you can get it for about £500.00 try print max.
  • Dan Osterbery
    26 May 2010 at 15:36
    hi soyeb,
    500 each or 500 for the 2? 500 pounds not too far away from 800 euros, so perhaps price not too bad!
    Dan
  • Soyeb Ravat
    26 May 2010 at 15:56
    Hi Dan Ive asked around in the past and they were approximately £500.00 which I have been quoted. Now correct me if i’m wrong but I think you get 2 heads in the SP Versacamms so unsure if they come as a pair or each. 😀 😀 😀
  • Gary Birch
    26 May 2010 at 15:58
    Dan
    Try here mate. Very good service and price.
    http://www.digiprint-supplies.com/index … lter_id=24
    Gary
  • Dan Osterbery
    26 May 2010 at 16:03
    cheers gary! thats the place everyone is talking about in belgium I presume? been trying to find it in google!
    cheers fella!
    quite a saving on what i have been offered, just need to find out if they are geniune roland parts, which i am lead to believe they are!
    thanks again!
  • Dan Osterbery
    26 May 2010 at 16:07
    Hi soyeb,
    yes i think your right! Each head drives two colours! So you need two head per machine!
    Dan
  • Jason Bagladi
    26 May 2010 at 16:08
    Genuine Epson / Roland print heads. Don’t forget to add 22% VAT if you’re not VAT registered in the UK. Still works out cheap though and my print head arrived next day!
  • Hugh Fraser
    26 May 2010 at 20:52
    Digi Print definetly do genuine parts, had a new main board for my CJ from them by return… and at a very good price.
    If you cant see it on the site contact them as they have much more which is not listed
    Roland had similar basic price but would have had to go to Japan and ship by boat 6-8 weeks or add additional costs for air express
  • Stephen Morriss
    29 May 2010 at 18:33
    How hard are these to change?
    Do you have to reset/recalibrate the head alignment?
  • Jason Bagladi
    29 May 2010 at 18:49
    You will need access to the service menu and the service manual to DIY it! Or pay someone around £200 to do it
  • Jason Xuereb
    1 June 2010 at 03:00
    Installing them isn’t hard. The vertical and horizontal alignment is the tedious part of the whole process. The heads screw in with 3 screws and you have these other two screws which move the head around to make micro adjustments to the heads. You need to loosen the 3 screws first to make the micro adjustments. Then you print out the vertical and horizontal alignment patterns I think they are called Bias something from memory. You keep doing it until they are all aligned.
    Robert over at http://www.signagespecialist.com can help you out with the heads and service manuals.
