Home Forums Printing Discussions General Printing Topics PRINT CUT QUESTION?
  • PRINT CUT QUESTION?
    Posted by Ryan Fairweather on 24 November 2006 at 09:15
    Morning guys!
    If i create some text in corel x3, & add an outline, create boundary and then give that text a cut path it seems to always be in the centre of that outline not to the edge.
    Have you any advice as to get around this?
    Ryan
    Dennis Van Der Lingen replied 18 years, 12 months ago 4 Members · 5 Replies
  • George Zerbino
    24 November 2006 at 12:09
    Ryan,
    Select the outlined objects, go to "arrange" on the menu bar, then click on "convert outline to object".
    This should solve your problems.
    Regards,
    GeoZ
  • Ryan Fairweather
    24 November 2006 at 12:26
    if i do that it seems to weld the object.If i then pull that outline away and add a cut path to that and it seems to add a cut path on both sides of the outline?
    I know the solution is there somewhere?
  • Nick Minall
    24 November 2006 at 12:31
    Try using a contour instead of an outline on the text.
    Nick.
  • Ryan Fairweather
    24 November 2006 at 16:00
    cheers Nick, will do.
  • Dennis Van Der Lingen
    27 November 2006 at 17:25
    when you have a double cutline you need to uncombine the object, delete the inner part and your done
