Home Forums Vinyl Cutter Discussions Roland Cutters print cut blade pressure
  • print cut blade pressure
    Posted by Dan Osterbery on 26 February 2009 at 09:24
    Morning all,
    quick question? I am cutting after laminating on a sp-540 at 140gr downforce and I appear to be only cutting through laminate not vinyl. Is my blade blunt and needs replacing or do you increase pressure to cut through both layers. It cuts vinyl perfectly when not laminated??
    I am using grafityp S022p and grafityp Lam170 gloss 70mc thick
    Dan
    Stephen Morriss replied 16 years, 10 months ago 5 Members · 6 Replies
    26 February 2009 at 09:43
    180 ish is not uncommon to cut both but 140 to cut normal vinyl is a little high. normally around 100
    some times help to slow it down when cutting laminated jobs to around 30
  • Dan Osterbery
    26 February 2009 at 09:46
    thanks chris! blade been in there a while and just wondered if its time for a change, and a bit new to this laminating lark!!
    thanks
    Dan
  • Derek Heron
    26 February 2009 at 10:01
    hi dan you will have to increase the pressure
    i normally do some test cuts as some laminates are thicker than others
    remember to drop the pressure after your job
    just put a new blade in my machine and cutting force down to 80 -90
    Derek
  • Nick Minall
    26 February 2009 at 10:13
    and make sure you have increased the blade sticking out to cut the lam and vinyl
  • Dan Osterbery
    26 February 2009 at 10:17
    thanks derek,
    just did a test at 180 and worked a treat! thanks guys, theres life in the old blade yet!!!!
    Dan
  • Stephen Morriss
    26 February 2009 at 10:18
    All the above plus check with each laminate you use, I’ve found there can be quite a difference between them.
    I’ve also forgot to change back for un-laminated, handy if the customer had wanted die cut stickers 😳
