• Mike Brown
    26 October 2003 at 09:35
    no reply yet Kev! 🙁 – it’s not my sort of thing, else I’d have let ya’ know?….
    …come on someone, lend a hand… 😀
    more soon
    mikethesign
    26 October 2003 at 09:53
    Difficult to answer this without knowing what would be involved in the installation. This is a very large box that will probably be made up from a number of sections. These will need lifting into place and aligned together, what are you going to be using for this and how will the sign be attached?
    Roughly I would say you are looking at a minimum of £4,000 assuming good access. This will be quite difficult so make sure you charge enough for it.
    Good luck 😀
  • Kevin Flowers
    26 October 2003 at 20:20
    Thanks for your reply Phil, accesss no probs, straight into brick work and only 2.5mtrs of ground. Ihave a feeling that i was going in to cheap £2500, box cost is a grand allow £50 for vinyl etc rest is labour. i think i’ll split the differrence on the two prices and go in at £3250. i am in a area where if you throw your scrap ball of vinyl away you’ll hit another sign writer so everything is kept competitive.
    Many thanks
