Home Forums Sign Making Discussions Vehicle Wrapping Precut stonechip
  • Precut stonechip
    Posted by Anthony Woodsford on 9 March 2011 at 16:44
    I was asked by a friend to do a precut stonechip install to his rear arch.
    Ive only done colour change vinyls before, so it was new, but thought it would be a doddle.
    Now.
    The vinyl wasnt proper stonechip guard, merely clear vinyl.
    I used an app tape to get the vinyl into position.
    I think (after looking on youtube) that this is where i went wrong.
    Should I have done a wet application for this? As in window films, or proper stonechip guards?! I got a fingerprint on the inside, and hence, the film was written off.
    i left the job unable to isntall the film, and most annoyed with myself for not managing it….
    Any advice is most welcome.
    CHeers
    Ant
    Chris Windebank replied 14 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Dorling
    9 March 2011 at 17:39
    Not done stonechip before but clear vinyl is a sod for fingerprints. I usually stick some tabs of masking or narrow app tape to hold onto so I don’t touch the back of the vinyl.
  • Chris Windebank
    9 March 2011 at 20:14
    stone guard film must be fitted wet. If you buy it by the metre at 610 you will need a 3rd pinch roller as this is very soft and will not cut properly.
    You can however make a template and cut by hand for the small jobs.
    Clean hands and soapy liquid ensures a good fit without those fingerprints
  • Anthony Woodsford
    10 March 2011 at 09:01
    cheers guys
    may just give this one another go and see how i gets on!
  • John Parfit
    10 March 2011 at 09:15
    You Mention that it was clear vinyl but not which type i.e. monomeric, polymeric or cast; if the arch was ‘arched’ then monomeric would not work, polymeric would struggle depending on the ‘archiness’, only cast would take to compound contours when applied as a sheet and certainly using application tape would not allow the material to contour.
    Good luck with your next attempt Anthony.
  • Chris Windebank
    10 March 2011 at 09:42
    Antony, as these are small blag a couple of A4 samples to use. Ventureshield I believe now. Showtrax in Bedford do it
  • Anthony Woodsford
    10 March 2011 at 09:58
    well, hes got a roll of them precut. and alraedy had one applied to the other side, so im guessing they’re just a cheap polymeric.
    The reason he asked me was that his cousin normally does them, as hes been in the signage industry years, and continues to mess them up.
    After i did a grafityp carbon diffuser for him, he asked me to do these, and theyre just over A3 length in size as they go up onto the rear arch.
  • Chris Windebank
    10 March 2011 at 10:05
    use the proper stuff as mentioned above from Showtrax, easy to fit and not that expensive
