Home Forums Printing Discussions Roland Printers Possible calibration needed?
  • Possible calibration needed?
    Posted by Dan Giddings on 28 June 2019 at 08:14
    Hi all
    I’ve attached a photo of a test print from my sp300v, do I need to be performing some sort of calibration to sort the gap in the middle, If so, which one should I do?
    Many thanks
    Dan Giddings replied 6 years, 6 months ago 2 Members · 2 Replies
    28 June 2019 at 10:30
    adjustment required is feed calibration normal vinyls 0 thinner cast + a bit thick banner – a bit think thats the right way round. if you alter the machine make sure vw is not over riding the value.
    some profiles have a feed value set but check if use machine value is active or not as required
  • Dan Giddings
    28 June 2019 at 10:35
    Thanks Chris I’ll perform the feed calibration and retest.
