Home Forums Sign Making Discussions Vinyl Please Help (Cold)
  • Please Help (Cold)
    Posted by Aaron Powell on 3 December 2008 at 19:28
    OK i was fitting vinyl today on a van that had been in this cold weather today, i started to fit it around 3.30pm it was PROPA Cold, i wet the vinyl a bit with a spray but it wouldn’t stick very well, when i tried pulling the app tape off the vinyl came with it and wouldn’t stick down to the van.
    Any idea?
    Brad Mulock replied 16 years, 10 months ago 6 Members · 6 Replies
    3 December 2008 at 19:36
    Yes thats normal 🙁
    you really shouldnt put vinyl down at less that 10 deg c
    and certainy not with water, in cold weather.
    You need to warm up the surface first or at least apply dry then give the vinyl a good going over with a heat gun
    You could try Rapid prep 2, I saw a video once of them using it on glass and in the snow?
  • Aaron Powell
    3 December 2008 at 20:12
    Ok i give it a go next time
    Thanks Peter
  • Joseph Helm
    3 December 2008 at 20:57
    I fitted some vinyls today dry, then went over the whole lot with the heat gun after.
    They seem to have stuck well.
    More to do tomorrow, I hope the weather holds!
  • Adrian Yeo
    4 December 2008 at 07:21
    Might seem a daft question, but when you sprayed the water on… did it freeze? It was zero degrees here at that time yesterday and a spray/mist of water would not take long to form ice! 😮
  • Peter Dee
    4 December 2008 at 08:15
    Well I went out in the van at 3.45 and had to scrape the screen – and that’s in the South!
    Certainly not vinyl fitting on a van weather.
  • Brad Mulock
    4 December 2008 at 10:19
    I’ve got three minibuses lined up for the next couple of days. I think i might be calling the customer after this post to put them off till spring. – I’m indoors creating artwork and that’s where I’m staying. 🙂
    Trouble is – I have loads of jobs on at the moment which are all coming to their conclusions and will all need installing. I guess the thermals and the thick gloves will have to come out of their hiding places and earn their keep.
