Home Forums Sign Making Discussions Vinyl Plastic Wheel covers….
  • Plastic Wheel covers….
    Posted by Phil Craddock on 29 January 2010 at 15:21
    I have a customers job in that requires covering their hard plastic and slightly textured rear wheel cover (4×4) with an all over base color which then needs trimming back to a shape before adding white-out text to.
    What type of vinyl should I use for longevity and to make sure it doesn’t just peel itself off??
    thanks in advance, Phil
    Phil Craddock replied 15 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Matty Goodwin
    29 January 2010 at 16:37
    Hi Phill
    I’ve had 5 4x4s with spare wheel covers and had my company advertised on all of them. Base colour in black with siver lettering…all in 5-7yr vinyl. don’t really see a need for cast.
    Matt
  • Phil Craddock
    29 January 2010 at 16:42
    cheers matty
    I suppose just as long as it get s a good de grease should be OK – I’m running a test with some Oracal 651 to see how it holds up.
  • Gavin MacMillan
    29 January 2010 at 16:54
    Important to get them clean if they have been on the road – also fit the vinyl dry to increase the initial bond as the texture may cause problems if fitted wet, especially at this time of year.
    29 January 2010 at 17:03
    I also have an enquiry for wheel covers, can anybody recommend a good supplier.
    Alan D
  • John Harding
    29 January 2010 at 17:17
    alan both graphityp and jag do them i think
  • Matty Goodwin
    29 January 2010 at 18:48
    Direct 4×4 do most makes and sizes. Remember you will need tyre and wheel size, there not universal!
  • Paul Humble
    29 January 2010 at 18:58
    Ive used 651 on a few and its more than adequate.
  • Phil Craddock
    29 January 2010 at 19:11
    hopefully the 651 will do the trick – also testing some Image Perfect vinyl – but the wheel cover does need a dam good de grease and clean before application.
