Home Forums Sign Making Discussions General Sign Topics Plastic scraper to stripping
  • Plastic scraper to stripping
    Posted by Alistair Richards on 26 May 2010 at 17:56
    Can anyone recommend a good plastic scraper for vinyl stripping, and supplier.
    I have some plastic blades from Grafityp which are really good, but the holder they come with is naff. I need something more robust.
    Thanks 😀
    D Major replied 15 years, 4 months ago 9 Members · 20 Replies
  • 20 Replies
  • Matty Goodwin
    26 May 2010 at 20:19
    The rubber disc that fit to a drill work for me! Expensive but worth the time saved and muscle!
    (sorry, forgot the name of them)!
  • Alistair Richards
    26 May 2010 at 21:03
    This what you mean Matty, http://www.jagsignsupplies.com/aqshop/c … hp?id=1300
    Any good on vans or not?
    Still could do with a decent scraper if anyone knows though.
    26 May 2010 at 21:34
    only thing i found was plastic chisels from draper tools,
    I dont think scrapers work very well though, except on Glass.
    A body shop supply company will stock "toffee wheels" a smaller but far cheaper alternative to jags high priced offering.
  • Alistair Richards
    26 May 2010 at 21:36
    Just found a UK supplier of the lil chizler, will give it a go http://www.chizler.co.uk/
    26 May 2010 at 22:09
    quote Alistair Richards:
    they are ok for cleaning pans. no good for stripping vinyl though
  • Matty Goodwin
    As Peter says, toffee wheels, that’s what I couldn’t remember! The Jag ones are pricey and wear down very quickly.
    There fine to use on vehicles and personally wouldn’t use any scrapper on a vehicle even if plastic! Run a plastic squeegee down your car and see the marks left!
    There is liquid vinyl remover similar to Nitromorse (NEVER use that tho) that works pretty well.
    Matt
  • Alistair Richards
    27 May 2010 at 09:16
    It’s not for scraping vinyl off, just to lift the edges when stripping to save my finger nails, and for working glue when softened. 😉
  • Matty Goodwin
    27 May 2010 at 20:54
    Ah, bless ya!!
    Best thing, a plastic scrapper that comes with car body filler!
    Like a squeegee but a lot thinner.
    Matt
    27 May 2010 at 20:59
    I prefer to use a single edge blade, hard to get hold of nowadays, but snap on vans sell them in boxes of 100 for about a tenner
    usefull for all sorts of stuff.
    You need to be care full but they are the best way to lift a corner of the vinyl
    27 May 2010 at 21:38
    Matty have used that vinyl remover thought it may be easier 🙄 it is more of a pain than doing it the hard way, it sort of melt’s the vinyl a bit like Peter said like nitromores and the gunge it leaves is unbelievable to get rid of 👿 think of the worst cold you have ever had 👿
  • Matty Goodwin
    27 May 2010 at 22:46
    I’ve never had the ‘snot’ effect when using it, but maybe just lucky!
    Saying that if we were all so precious about our finger nails as Alistair seems to be I wouldn’t strip, fit or clean anything!!!!!
    :lol1: :lol1:
    27 May 2010 at 23:08
    Matty maybe just left to long 😀 it wasn’t pleasant 😀 maybe Alistair has no finger nails ? I don’t use a blade cause I can’t be trusted with sharp instruments 😀
  • Matty Goodwin
    27 May 2010 at 23:44
    Maybe a scalpel with a cork on the end?
    Matt
  • Karen Spooner
    28 May 2010 at 08:57
    I’ve got a couple of these q.r tools – get them from motor factors as well. They have metal blades or you can get plastic ones, sure they were from Victory but can’t see them on the website? I use a hairdryer (hi tech!), warm the vinyl and use my "special tool" . . . .
    Best thing for getting glue off is Tar & Glue Remover, again from motor factors. If there’s lots of glue soak it with the tar & glue remover on a rag then use the plastic blade . . . does get a bit snotty tho!
  • Alistair Richards
    28 May 2010 at 09:13
    nice one karen, that’s the sort of thing i’m looking for 😀
  • Tim Painter
    28 May 2010 at 09:28
    Lift Sticks are handy….I can’t recall who sell them though.
    Very similar in material to the tools Draper sell that Peter mentioned.
    28 May 2010 at 11:06
    I have used a L’iL Chizler with satisfying results for many years, combined with a hair dryer to loosen the grip of the vinyl with Rapid Remover for the adhesive and loads of paper towels.
    The Chizler does save the fingernails, but on a big job I sometimes get bad blisters just from friction, not the hair dryer.
  • Karen Spooner
    29 May 2010 at 11:26
    😉 Cool, glad to help! Try Mill or Snap On . . .
  • Richard Martin
    29 May 2010 at 18:43
    I have been using these for removing vinyl have found them to be ok
    10th item in the list vinyl removal tool
    http://www.mdpsupplies.co.uk/productcat … tname=Sign Making Tools&parentcat=7
    Sorry it wont give me a direct link
  • D Major
    16 August 2010 at 11:45
    Spandex do some good plastic scrapers same size as gold squeegees. They are green and have two sharp edges – they work well.
    good luck,
    Dick
