Home Forums Sign Making Discussions General Sign Topics Pin Pen sort of thing
    13 February 2007 at 19:44
    Alister why do you want one? a sharp scalpel or needle will do the same job 🙄
  • Alistair Richards
    13 February 2007 at 20:24
    Just thought it would be handy really, prefer using a pin, but keep losing it under all the other tools. 😛
    13 February 2007 at 21:16
    Alistair I think graphityp do a similar gadget, If have a couple knocking about, but they are a bit dangerous. If you forget that its not a pen and decide to pick your nose or ears with it….or scratch a phone number on the back of your hand!!
  • Micheal Donnellan
    14 February 2007 at 02:37
    How about having a go at making one. Convert a clickpen, Remove the metal nib from the plastic ink tube. Best use a old empty pen as this would be messy. get a needle and glue it in the tube.
    Result clickpen needle vinyl bubble popper thinghy.
    14 February 2007 at 02:47
    Michael, I have wanted to try that for a long time. Trouble is I keep losing the pens before the ink runs out :lol1:
    Alistair, it sounds like you have far to much money, just send it all to me then you won’t have to worry about buying all these fancy gadgets that you don’t really need. Signmakers aren’t suppose to get bubbles so you shouldn’t need one anyway !!!!
  • Phil Halling
    14 February 2007 at 08:20
    The theory behind these types of tools – 3M make one called an air release tool, is that with the best will in the world a scalpel or blade will make a slit rather than a hole. This tool makes a round hole, therefore the tension on the vinyl is equal all around, a slit makes an unequal tension situation – theoretically making it more likely that the vinyl will split open over a period of time.
  • Mike Uhruski
    15 February 2007 at 10:40
    irish sign&digital would have those 🙂 – 3m make (dont know if they operate on the other side of big water though)
