Home Forums Sign Making Discussions Vinyl photoluminescent exit signs – should i produce inhouse
  • photoluminescent exit signs – should i produce inhouse
    Posted by Martyn on 24 January 2019 at 13:47
    Hi all, im quoting a large job atm and within it is 30 off photoluminescent exit signs.
    I was going to buy these in but prices seem pretty high, then thought can i produce them. Not something i have done before, having read through old posts seems its more than possible but i have a few questions –
    Is there an eco solvent printable vinyl that would give good results?
    Is flooding the sign in photoluminescent vinyl then overlaying normal green cut vinyl a better option?
    Do either of these options work that well?
    Is it a waste of time and just buy them in :smiles:, just thought if i look into it could be some production money to be made out of it.
    Thanks in advance, hopefully someone has tackled this before
    Robert Lambie replied 6 years, 10 months ago 3 Members · 6 Replies
    24 January 2019 at 13:59
    I did this using some 1.5mm (?) phosoluminescent solid pvc sheet. printed onto clear and just laminated it on! I’m certain I bought the panels through a former incarnation of europoint but when I last tried to get some they didn’t have a clue what I was talking about. I’m fairly certain it was an oracal / orafol product,
  • Martyn
    24 January 2019 at 14:40
    Thanks hugh, ok didnt even realise you could buy it in sheet form. Something else on the list of maybes :thumbsup:
    24 January 2019 at 15:36
    Oracal does a great photoluminescent that you can digitally print. its the closest to white I have seen, yet photoluminescent.
    CLICK HERE
  • Martyn
    24 January 2019 at 15:44
    quote Robert Lambie:
    CLICK HERE
    Thats great robert i will check if my supplier
    24 January 2019 at 15:46
    that’s cool Rob,
    Do you know if it’s affected by the heat in a latex at all?
    24 January 2019 at 16:06
    quote Hugh Potter:
    that’s cool Rob,
    cant see it mate, we have done a pile of safety signs using it just recently and god knows many over the years.
