Home Forums Software Discussions General Software Topics Perf cut help in Onyx postershop 12 please
  • Perf cut help in Onyx postershop 12 please
    Posted by Dan Osterbery on 10 March 2017 at 13:39
    Hello All,
    we use illustrator and have had cut contour and perf cut contour for a while, and we used to cut stickers on our roland sp540. We have now bought a hp 560 latex and onyx postershop 12. We are having a problem getting the perf cut contour to work. It works in versaworks but not in onyx in the same file? I have the two cut contours on different layers, but i cannot seem to get the perf contour to work! We are trying to cut the stickers out on a graphtec 8600. can anyone talk me through the way they would do it?
    As im new to hp and onyx does anyone recommend a website or forum for onyx that i could do some more reading?
    thanks in advance
    Dan
    Dan Osterbery replied 8 years, 8 months ago 2 Members · 2 Replies
  • David McCarroll
    10 March 2017 at 22:28
    Hi Dan,
    When doing (what I think your doing), are you using the cutter setup through onyx to get the 8600 to cut?
    I’ve found onyx and graphtec never worked that great so we stick with the marks within illustrator then do the cutting through cutting master, in cutting master you just select the pert option along with the destance between perfs etc.
    Hope this makes sense and helps
  • Dan Osterbery
    11 March 2017 at 08:58
    Thanks I’d forgotten about cut master! I’ll explore that option thank you!
    Sent from my SM-G901F using Signapp mobile app
