Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Pcut630 – trouble setting knife and cutting
  • Pcut630 – trouble setting knife and cutting
    Posted by Rich Fereday on 18 January 2012 at 17:25
    Hi I was wondering if anyone could help?
    I have a Pcut630 and am using signcut pro, although i have everything set up and the software is speaking to the plotter when cutting out heat press vinyl (apologies if this isn’t the correct name, I’m new to it all) I can’t seem to cut through the material? or it cuts to much and destroys it.
    I’ve tired different pressures have set the knife blade to a recommended 1/2 thickness of a credit card. I would assume it’s something I’ve not got set up quite right?
    Any help would be massively appreciated
    Rich
    Chris Wool replied 13 years, 9 months ago 6 Members · 12 Replies
  • 12 Replies
  • Derek Heron
    18 January 2012 at 18:00
    best if you say hello and introduce yourself in the say hello section
    you should back off the pressure and gently increase it you only need to score the heatpress vinyl and remove the excess
    leaving the required text or logo (in reverse)
    hope this helps
    derek
    18 January 2012 at 19:14
    Have a look through the Pcut plotter section, lots of stuff in there on setting them up.
  • Graham Shand
    18 January 2012 at 21:00
    A few things, you did not mention type of vinyl, flock, glitter etc etc, they all require a different pressure, with the Pcut you would require a min of 110 for standard vinyl , but do a test cut first starting from 90 , also is it a new blade ?, I would also use a 60 degree blade for flock and a 45 degree blade for standard heat press vinyl, it is trial and error and a steep learning curve, the other thing is slow the speed way down. The thicker the material the higher the pressure required. good luck
  • Rich Fereday
    19 January 2012 at 10:39
    Gents
    Thanks very much for this, thought it might be a case of trial and error!!
    Rich
  • Brian Carey
    19 January 2012 at 13:58
    Try getting some smart blades from Edward Mathias, they come preset, i use them in my 630 and find them great, no messing around trying to set them up, when they are blunt you send them back for replacements,
    I use a press pressure of 100 upwards for standard vinyl.
    BC
  • Brian Carey
    19 January 2012 at 14:00
    forgot to mention try setting the cut speed to 50
    gd luck
    BC
  • Rich Fereday
    19 January 2012 at 14:09
    Brian
    Thanks very much for this.
    Sounds like a plan to me!!
    Rich
  • Rich Fereday
    4 February 2012 at 12:23
    Dear All
    Thanks for the previous advice, the smart knife worked wonders!!
    However, I’m now having problems with cutting, I’ve set the compensation, pressure and speed but am not getting consistent cut’s, the media doesn’t seem to be held in place tight enough, when cutting it "ruckles" up.
    I’m cutting heat transfer vinyl.
    I’ve unrolled the media, cut a section to use so it feeds through, but still can’t seem to resolve the problem.
    Does anyone else with a pcut 630 have these problems or a solution (?)
    Rich
    4 February 2012 at 12:38
    Don’t cut the material myself but from posts I have read on here some heat press vinyls require a 60 deg blade rather than a 45 deg blade. People have also mentioned that you need to slow the speed right down for cutting certain types. Placement of rollers is also important with any media your cutting.
    4 February 2012 at 16:14
    quote :
    However, I’m now having problems with cutting, I’ve set the compensation, pressure and speed but am not getting consistent cut’s, the media doesn’t seem to be held in place tight enough, when cutting it “ruckles” up.
    if you can see the vinyl and backing lifting in places as the knife changes direction then, one of these
    cutting strip has a sharp gouge in it.
    knife blunt and too much pressure
    cutting too deep you only need to cut the vinyl
    the backing paper is sticking to the bed or the cutting strip so not slipping when under knife pressure (clean and polish)
    pinch rollers positioned too far out to the edge.
  • Rich Fereday
    4 February 2012 at 16:22
    Gents
    Thanks very much.
    Yes the cutting strip does have a "cut mark" in it.
    I’ll look to replace this.
    Rich
    4 February 2012 at 16:27
    if its a hard plastic type of strip you can wet and dry paper it smooth then put a strip of vinyl over it, as a temp repair.
