Home Forums Printing Discussions Roland Printers PC60 Printing problem.
  • PC60 Printing problem.
    Posted by storeinet on 6 August 2004 at 16:17
    I’m trying to print the attached file on a PC60 via signlab. 6 r13 but it keeps stopping mid flow.
    It will print the red spot 21 but fails to print the black 12. Both spot colours are loaded and enabled in the print setting.
    I have tried with it with trapping on and off to no avail. I’ve also changed the black cartridge in case it was that, no joy.
    I seems that it goes to pick up the cartridge and then just gives up. Then the busy and colour lights just flash.
    I’ve even tried it removing the invisible welds and still no joy.
    Can some one please enlighten me?
    Dan
    http://www.signs-livery.co.uk/sheep.cdl
    Chris Wool replied 21 years, 5 months ago 2 Members · 6 Replies
    6 August 2004 at 16:31
    dan
    best guess at present is if the colour light is flashing then it is looking for a cart in has not got the busy light flashing is a goog sign cos it means all is well if just ant got the stuff to carry on with.
  • storeinet
    6 August 2004 at 16:44
    Hi Chris
    I my job palette there are 3 colours spot black spot red and invisible.
    Both the red and black carts are loaded, I’ve even ensured there the correct way round.
    Dan
    6 August 2004 at 16:55
    i cant open your file – when it stops whot colour should in do next i dont know any thing about signlab – i would also put a set of cmyk in aswell as your spot red just to see if you put on traping then it wants all cmyk as also photo colour
  • storeinet
    6 August 2004 at 17:00
    It prints the red fine so by rights it should be printing black next, i have just changed the Invisible to clear but get the same results.
    Dan
  • storeinet
    6 August 2004 at 17:07
    heres the file in AI format
    http://www.signs-livery.co.uk/sheep.ai
    6 August 2004 at 17:39
    my guess is its looking for white.
    personally i would change all red to 100% mag and put a mag lable on to the red ribbon case then spot colour problems do not excist
    files made in this manner can be very hit and miss to a lot of drivers
