Home Forums Printing Discussions Roland Printers pc60 head change – HELP REQUIRED
  • pc60 head change – HELP REQUIRED
    Posted by shaunad on 23 March 2008 at 18:46
    Hi All
    I have ordered a new print head from Lcheapo but understand i need a service manual to change and setup the voltage.
    Is there anyone out there that can help????
    Shaun
    Richard Urquhart replied 17 years, 9 months ago 3 Members · 3 Replies
  • Jason Bagladi
    23 March 2008 at 21:11
    May be different, but with the PC600 replacement head, it came with a disc that allowed you to set up the head voltage.
  • botec
    24 March 2008 at 13:44
    I can send you the service manual for PC60.
    Send me you mail
    Pierre
  • Richard Urquhart
    24 March 2008 at 15:37
    When the new head comes it will have the voltage hand written on a Small sticker on the top of the head, the disc that comes with it wont set the voltage, the voltage is set on the main board, for example 24.6 volts, to check the voltage you need a multimeter and then dial the voltage to match the head, there is a small wiring harness available from roland that plugs in to a socket near the voltage adjustment screw, then connects to the multimeter. the set up is very easy to do along with the head alignment.
