Home Forums Sign Making Discussions Computers – Tablets – Phones PC has / is dying – help please
  • PC has / is dying – help please
    Posted by Warren Beard on 27 July 2010 at 14:40
    So I know this has been covered a few times but now my PC has pretty much died on me. It has been working fine the last few months, I re-installed windows so it was a fresh install and upgraded the service packs etc and had versaworks installed when I got my printer and all has been good until about a week ago when I started getting blue screens at start up with a USB-Bug or something, anyway just restart a few times and it would come right.
    now it won’t even boot up and in the bios settings it says cpu over heating 😮
    so is it toast and needs to be shipped to nigeria for them to steel old information deleted but not gone off the hard drive ? 🙄
    The big question is do you think it will be OK to go into PC World and buy a decent PC with all the latest software etc (as I know these are sometimes an issue)
    ALL I USE THE PC FOR IS VERSAWORKS RIP, so will a standard off the shelp PC be good enough?
    Need to buy today as I have stuff to print 😕
    many thanks
    Warren
    Alan Wharton replied 15 years, 5 months ago 6 Members · 12 Replies
  • 12 Replies
    28 July 2010 at 10:36
    Hi Warren,
    how much is a standard "off the shelf" pc these days? i got a pretty top end pc (quad core, 3gigddr2, 400gig hdd, big lcd monitor, etc) for about £750 worth of signage at my local shop, total cost to me was about £250.
    if you’re not lucky enough to have a shop that needs signage then still pop in there, i recently bought, as a back up (when i needed it!) a refurb’d tower only with 120gig hdd, 2gig ram and dual core processors, it doesn’t have to run a power hungry rip but does all i needed it too for £60!
    28 July 2010 at 10:39
    ps, blow out and vacuum the tower / motherboard / fans on top of the cpu and heatsinks, if they’re clogged with dust then airflow doesn’t move so well and it will overheat.
    i made a makeshift hoover attachment using a pop bottle and a piece of 1/4" pipe for inside the pc, amazing how much cack gets in the fans etc.
  • Richard Urquhart
    28 July 2010 at 11:19
    Warren I have 2 systems. 1 running xp pro for the printer and cutter.
    the other an Hp quad core with 4 gb ram running signlab etc etc very fast copes well with massive files and was around £699 in pc world around a year ago. I never like the ones the smaller shops put together as some components conflict with eachother, just think its easy to go in to pc world and get one thats been tested.
  • Stephen Morriss
    28 July 2010 at 14:00
    Should be fine Warren.
    I thinks it’s fine with Windows 7, do a quick search.
    Make sure it’s got a 32 bit OS though as Versaworks isn’t designs for 64 bit yet.
  • Warren Beard
    28 July 2010 at 14:30
    Thanks guys
    I spoke to Signmaster about 64 bit and they said Versaworks will run fine on it but it cannot be Windows 7 Home, must be Professional or the top one what ever it’s called.
    both my local computer shops haven’t got back to me, the one I already have/do a lot of work for but like I said no response and he’s always on the road (although he always phones me late at night when he needs something 🙄 :lol1: )
    Am worried that if either I upgrade my current or get a new one built it is going to take days, I have work waiting to be done and need one yesterday 😥 That’s why I was thinking PC World as I could buy one now but also don’t want to waste money or sacrifice on speed etc.
    Warren
  • Stephen Morriss
    28 July 2010 at 15:18
    The Roland site just says Windows 7, doesn’t mention anything about it having to be Pro or Ultimate.
  • Warren Beard
    28 July 2010 at 16:06
    quote Stephen Morriss:
    Steve I’m not sure, all I know is I was told if it’s a 64bit machine it won’t work on home edition, I presume it will work on home edition on 32bit.
    does anybody know for sure?
  • Stephen Morriss
    28 July 2010 at 16:12
    Ahh right.
  • Simon Strom
    28 July 2010 at 18:00
    If the pc is overheating you might take it apart and clean the thermal grease out. Re-apply some Arctic5 Silver Thermal Grease on it. They have some solution that’s suppose to help take off old thermal grease. I just use electrical contact cleaner solution and some cue tips though. I’ve had a few PC’s with overheating issues and that helped. If something has blown on the board it won’t help of course. But it’s a super cheap and easy thing to do.
    http://www.arcticsilver.com/as5.htm
    http://www.arcticsilver.com/arcticlean.htm
  • Simon Strom
    28 July 2010 at 18:01
    I guess I should have said that the thermal grease is applied between the heat sink / fan and the processor (AMD, Intel) chip. Just in case you weren’t aware of what I was referring to.
  • Warren Beard
    28 July 2010 at 19:08
    well I took the fan out and the big funnel tube thingy and gave it all a good clean as it was very very dirty, powered up first time after a good clean, I hope all the other blue screen issues I was having will go too, time for some more Ram me thinks.
    I just can’t believe I approached 2 local computer shop (one I do a fair amount of work for) and none of them got back to me after I told them I need to buy a PC off them, obviously it’s the right business to be in when you don’t need customers coming to you to buy your goods.
    warren
  • Alan Wharton
    29 July 2010 at 12:17
    iv had the same problems of blue screen over and over again which like yours turned out to be dust in the cpu heat sink but a good blast with me air line sorted that and worked great, had same prob again a few months later but it turned out to be the power supply was fried and kept blue screening, new 800w ps all ok again, but pc’s certainly dont like getting hot, there is monitoring software you can put on your pc that gives an alarm if cpu gets above a set temp.
