Home Forums Printing Discussions Roland Printers pc 600 question
  • pc 600 question
    Posted by Derek Heron on 10 February 2006 at 17:05
    before i run some tests or even worse read the manual can any body tell me the max print height from a single pass on my pc 600
    thanks Derek
    Chris Wool replied 19 years, 10 months ago 4 Members · 5 Replies
  • Jason Bagladi
    12 February 2006 at 19:22
    The ribbon is 13mm so I would guess just a bit less than that.
  • Derek Heron
    12 February 2006 at 19:39
    thats what i presumed but ran a print of 10mm high and it went in two passes?
    any ideas
    Derek
  • Mike Grant
    12 February 2006 at 21:06
    The Colourcamm works on a set grid pattern. if the top of the letter is only 1 tenth of a mill over the gridline it will make a pass just for that little bit. It is really annoying and ribbon wasting but you have to live with it.
  • Derek Heron
    12 February 2006 at 21:17
    thanks mike thats stopped me going mad i tried nudging it up and down to no avail some you win some you lose
    regards
    derek
    13 February 2006 at 10:14
    hi
    the pc60 is a 8mm print width. as mike says the printing grid starts at the plotter 0 0 so a 10 mm letter could be 3 passes.
