Home Forums Printing Discussions Roland Printers PC 600 Problem
  • PC 600 Problem
    Posted by Jason Bagladi on 2 January 2006 at 22:49
    Help! Mid print and the cartridge runs out! Change the cartridge, close the cover, carriage picks up the cartridge but nothing else happens. Busy light is flashing, but no printing!
    Any ideas??
    Phill Fenton replied 20 years ago 3 Members · 4 Replies
    2 January 2006 at 22:57
    Switch it off and start again 😕
  • Jason Bagladi
    2 January 2006 at 23:01
    Just done that, but there must be a way to continue a print from replacing the cartridge.
    Could it be that I didn’t have a second cartridge ready and had to put a new ribbon in the empty cartridge and the unit timed out?
    2 January 2006 at 23:12
    it continues once new one is loaded. as phill says, restart might be needed but if you have done this and it persists. theres a problem somewhere!
    if you have say 4 black carts and one runs out, it just picks the next available and continues… if you have one black and it runs out, you replace it close the door and it continues,,,
    2 January 2006 at 23:18
    The printing should have continued on once the cartridge was replaced. However, occasionaly these machines get their knickers in a twist and the only fix is to switch off and start again. Chances are it’ll be fine afterwards.
