Home Forums Printing Discussions Roland Printers PC 600 – How do I print spot colours?
  • PC 600 – How do I print spot colours?
    Posted by Jason Bagladi on 11 April 2006 at 20:58
    I am using the Roland Windows driver NOT ColorChoice RIP and cannot set spot colours to print. All design is done on CorelDraw12. Please help!!!!
    Jase
    Alex Pirozek replied 16 years, 4 months ago 4 Members · 4 Replies
  • Mike Grant
    12 April 2006 at 22:26
    Find the RGB or CMYK value in Corel then set up this value in the printers driver and save the colour. Be sure that you always use the exact same blue each time or the printer wont pick up other shades of blue. (blue used just as an example)
    I hope this makes sense! 😕
  • mahdesign
    18 April 2006 at 20:59
    I use a Windows 98 based system as it has a better driver for the PC600 which allows you to use all the spot colour options.
    If your using Win XP and trying to do a 2 colour spot forget it I spent days trying to get it working and gave up.
  • Fabrice Menard
    2 September 2009 at 15:46
    hello all,
    I have a similar problem at the moment. Well it is not really a problem since I managed ColorChoice RIP to do the job correctly.
    I’m using Illustrator CS3 or CS4: whenever I want to print spot colors or cut both are printed with the CMYK cartridges (e.g: cut contour is printed in Magenta instead of cutting) although Spot colors and cutting are enabled in the windows driver. I am running XP.
    When I export exactly the same file to eps (version for AI8, later version format does not work) and send to the PC600 usiong ColorChoice, spot colors are correctly printed and cutting is OK.
    Is there any trick or special print settings in Illustrator so that spot color and cutting works directly when printing from Illustrator?
  • Alex Pirozek
    2 September 2009 at 21:04
    Hi Jason,
    You can either use the default userinks.cpl palette in corel or create a new palette with the following values.
    Colour pallete settings for PC60 / PC600 and Corel Draw
    All need to be in this order and in RGB ONLY as the driver will only recognise these values for each colour.
    Red = 255-0-0
    Green = 0-255-0
    Blue = 0-0-128
    Cyan = 0-255-255
    Magenta = 255-0-255
    Yellow = 255-255-0
    Orange = 255-128-0
    Black = 0-0-0
    White = 255-255-255
    Gold = 128-128-0
    Silver = 128-128-128
    to print in these colours you need to select from process cartridge
    Y,M,C,K CR-MR Resin from drop down list
    and then go to special and select the colour cartridge required.
    Then UCR = Spot colour.
    Make sure that all colour cartridges have the correct barcode labels on.
    Alex.
