Home Forums Printing Discussions Roland Printers PC 600 – Best Vinyl to Use
  • PC 600 – Best Vinyl to Use
    Posted by Jason Bagladi on 17 February 2006 at 00:10
    I seem to be getting mixed results regarding print quality using my PC600
    When printing on to heat transfer vinyl, the results are fantastic, but on standard white vinyl I get banding, line which don’t print etc. I clean the vinyl and head everytime using Isopropyl Alcohol. Any ideas?
    Jase
    Derek Heron replied 19 years, 10 months ago 2 Members · 2 Replies
  • Rodney Gold
    17 February 2006 at 05:52
    We found using the cheap stuff worked better than high quality , however one thing to check is the little foam roller next to the head , it is actually what lays down the resin on the vinyl , NOT the head. This has to be in EXCELLENT condition otherwise you get drop outs etc. (they get graunched and dirty over tiume) The printing platen must be clean too and MUST be able to rock freely – make sure its also in great condition and the channel its in is clean.
    Pre heating the vinyl helps too
    If you are seeing a thin white line , you either have an alignment issue (details of how to fix in the manual) or a blown head.
  • Derek Heron
    17 February 2006 at 08:41
    make sure isoprop is dry also make sure there is no static when you clean and always roll out more than enough vinyl i always clean vinyl even if not printing so the head dont pick up dust etc
    get a new head cleaning pen from roland the one i got with the machine looked ok but was dry and wasnt doing anything never tried printing on cheap vinyl try posting a pic so we get an idea of your problem
    Derek
