your importer should have them in stock uk cost £200.
if you have a mechanical background its easy to change the head but the setting up seams to take for ever but should be done with a lot of care else it will never print correctly.
Make sure you buy the ‘thingummy’ probes to calibrate the head at the same time-it’s only about £5, but I was charged a fortune in postage buying it later.
You can’t set up the voltage without it. Doh! I know what I mean, someone else may be able to explain better 😳 😳
Please note:
