Home Forums Sign Making Discussions Vehicle Wrapping Part wrapping rear quarter to front wing – advice please?
  • Part wrapping rear quarter to front wing – advice please?
    Posted by Daniel Evans on 19 May 2015 at 15:22
    Hi guys
    I’ve got this job booked info later this week, i’m fine with applying the graphics i’m not 100% sure on what is the best way to cut the material.
    Firstly: Both colours are solid vinyl, no printing.
    I’m thinking cutting both parts on the cutter to cut the angled lines and then using tape to trim the top on the quarter panel, this way the line is perfectly inline with the green part and I can trim the bottom and top as needed.
    Can anyone confirm whether this is the best way to go about it or would you suggest a different method?
    Daniel Evans replied 10 years, 6 months ago 2 Members · 2 Replies
  • Unknown Member
    19 May 2015 at 16:31
    My advice would be to apply is as a rectangle and use knife less tape to get a smooth cut on that curve…
    Check this out!
  • Daniel Evans
    19 May 2015 at 18:30
    Hi James, that was my other idea but I thought I would get a better cut line on the machine
