Home Forums Sign Making Discussions Vinyl Pantone to vinyl match please
  • Pantone to vinyl match please
    Posted by Warren Beard on 6 February 2008 at 00:13
    Can anybody tell me if there is an exact match (well as close as absolutely possible) for the following Matt pantone colours.
    526 Matt
    275 Matt
    268 Matt
    513 Matt
    7437 Matt
    Customer does not want it printed and insists on cut vinyl.
    Warren
    Warren Beard replied 17 years, 9 months ago 5 Members · 13 Replies
  • 13 Replies
    6 February 2008 at 00:24
    Warren, show him your swatches, and ask him which colours he wants, otherwise you will never match so many, even with print, its almost impossible to match on vinyl, and guarantee a pantone.
  • Warren Beard
    6 February 2008 at 08:40
    Hi Peter
    The problem is it is for a very large retail company and if I can get this work it will be brilliant for business, his logo is made up of these colours and due to the application he wants it in cut vinyl and as colour accurate as possible. None of the colours overlap each other and it is all for interior use so I was hoping to find colours across all the ranges of supplied to match these.
    I have a Pantone book on the way but thought I might get a head start here 😉
    I will also be doing some printed logos but he still wants the cut vinyl as well. 😕
    Warren
  • Kevin Flowers
    6 February 2008 at 08:47
    Warren
    you could try Spandex and the Avery range don’t know if they do it in matt but they do have matched Pantone colors. However i think you have to buy a full roll per color.
    6 February 2008 at 08:52
    If these are to be in a matt finish – your choice is even more limited.
    However if gloss – I would suggest the following as the closest if can find in the Oracal range (751)
    526 = 40
    275 = 518
    268 = 403
    513 = ?
    7437 = 42
    None are exact matches – and it depends on the lighting conditions under which you look at the colours.
  • Warren Beard
    6 February 2008 at 09:31
    Thanks guys
    I know Matt is going to be a problem but all their graphics are matt and are matched to the matt (uncoated) Pantone.
    Would printing and contour cut work?
    Warren
    6 February 2008 at 09:33
    Yup – That’s how I’d do it
  • Kevin Flowers
    6 February 2008 at 11:12
    Warren
    i have printed onto matt removable grade in the past with good results, however color match is another issue.
  • DaneRead
    6 February 2008 at 16:20
    your best bet for indoor point of sale it this.
    Print it onto a UV flat bed machine. UV inks give off a very nice matt finish. Try and find a local printing house with a good UV machine. Get them to die cut if possible or maybe you can cut them manually yourself.
  • Warren Beard
    6 February 2008 at 17:24
    Thanks again all
    What are my best options for an accurate digi print? I need to get these logos printed but must be as close to the pantones as possible?
    Warren
  • Warren Beard
    6 February 2008 at 18:01
    Can a Gerber Edge do pantone colours and on to clear vinyl? This could be an option I could use instead of printed and contour cut or looking for cut vinyl colours.
    but only if customer is willing to have gloss I suppose, but can a Gerber do it?
    Warren
  • DaneRead
    7 February 2008 at 10:41
    IS IT GOING ONTO A WHITE BACKGROUND??
    IF SO THEN YOU COULD USE A MATT CLEAR STOCK AND PRINT UV.
    UV GIVES VERY GOOD COLOURS AND YOU SHOULD GET THOSE PANTONES ACCURATELY.
    NOT FAMILIAR WITH GERBER
  • DaneRead
    7 February 2008 at 10:45
    WHAT DOES YOUR CLIENT HAVE AT THE MOMENT??
    IF IT IS CUT VINYL THEN IM SURE YOU COULD FIND A MATCH.
    BUT I DID HAVE A LOOK AT THE COLOURS AND THEY ARE NOT EASY TO MATCH. SO I VERY MUCH DOUBT THAT HE HAS EXISTING CUT VINYL BRANDING.
    HAVE A LOOK AS TO WHAT HE HAS NOW AND TRY AND MATCH THAT CLOSEST.
  • Warren Beard
    7 February 2008 at 11:10
    Thanks for the input Dane, I am just waiting for him to get back to me as I did ask him those same questions. I don’t think he has had it in cut vinyl before but it is going on to a frosted perspex panel and this is why he does not want a square printed logo.
    Warren
